Jack e up issue?
So I'm trying to install a jack e up on my 2016 Outback and it doesn't fit. The base plate is hitting the bolts on top of the tongue. Any suggestions, do they make a smaller base?
  • jkjenn
    jkjenn Member Posts: 6,425
    It isn't a tight fit on my 2015. Based on @PXLated's advice, I used washers as spacers.
  • Nomad
    Nomad Member Posts: 7,209
    Yep - Mines that way. Seems very unstable looking and everything doesn't match up precisly but once the little wings get the weight on them, everything is solid. Been using mine for 20 months without a problem. Next time I unhook, I'll shoot a pick of how I align them.
  • Nomad
    Oh, mine sits on top of those bolts like that also.
  • JK5756
    JK5756 Member Posts: 25
    thx jkjenn...I was thinking washers might work.
  • JK5756
    Good to hear, thx PXLated. It did look really unstable and iffy. I'll give it a try again in the AM.
  • dinzzy
    dinzzy Member Posts: 182
    I installed a Jack E Stand which made it solid.  I had to grind it some so it would fit.
  • MrAmazon
    MrAmazon Member Posts: 61
    Same problem here...used washers like Jenn
    2016 T@B silver Sofitel/Outback combo, 2012 Jeep Wrangler Sport TV, Kernersville N.C.
  • John_and_Kris
    John_and_Kris Member Posts: 302
    Has anyone addressed the "issue" with the Kent Madison at the Jackie e up factory?
    When I had raised the issue with him back in February he said to use 3/8 washers to raise it up and get longer bolts. If LG is selling these devices in their store and they do not fit they should provide the washers/bolts so they do ; make a change (expensive) to the tongue area or at least inform people of the problem with the newer T@B's
    South Carolina
  • Nomad
    John/Kris - LG's not selling THE "Jack-E-Up" as far as I know. They do sell a unit custom made for the T@B, completely different deal. The Jack fits the trailers it was designed for and works on the T@B with the washer addition. I think I was the first to get one way back when they first came out and did the washer thing to fit. Has worked fine but the one LG sells works with no mods.
  • John_and_Kris
    Ok I went to the T@B site Store and found the Jack e Up I thought this was connected to LG I guess not then. I assume the one they sell at this site has the problems discussed here.
    Where does one find the one that LG sells for the T@B's w/o using washers?
    South Carolina
  • Nomad
    John/Kris - Now I'm confused and have to apologize, there is the JackE in the shop - I thought they changed to carrying the jack remover developed by a forum member (poptab?) - Don't see that on there though. Hmmmmmm
  • Tabaz
    Tabaz Member Posts: 2,420
    PXL - Search for "removable tongue jack" to find it.
  • John_and_Kris
    No need to apologize confusion is fun sometimes
    South Carolina
  • John_and_Kris
    It appears that washers are the only solution for T@B"S In the  Search section washers were also called for now I to am confused guess washers do not reduce strength
    South Carolina
    Tear Drop Shop under TaB Accessories - Removable Jack Plate.
  • Nomad
    edited July 2016
    John/Kris - I think I was the first to get the JackE way back when I got my T@B and washers seemed the only solution to raise the JE above the T@B bolts - As long as they're nice solid washers tightened down good, the JE donut is solid. Haven't had a problem with that at all.
  • John_and_Kris
    Thanks PXLated This will be our next purchase
    South Carolina
  • larrygon
    larrygon Member Posts: 255
    I also use washers with my JEU. Been using it this way over a year and have not had any issues.
    "Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
    2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
  • gulfarea
    gulfarea Member Posts: 524
    For those that use the JEU verses the one poptab made, I went with poptab as I made the mod for stowing the sewer hose and it looks to me like the JEU might interfere with the opening of the sewer compartment door. I find that sewer compartment to be the most useful mod I have done so far.  I keep all kinds of stuf in there. Those with the JEU will the sewer compartment mod door open and not hit the JEU? Thanks Art
    2019 TaB 320 S Boondock Edge
  • Nomad
    If the custom one by poptab had been available back when I needed one, I'd have gone that way. It's custom designed for the T@B.
    Just to update those of you who are interested in the Removable Jack Plate available at TearDropShop.com, it may say "Sold Out".  I called to inquire and it sounds like they are made to order.  She said it is about a 2 week turn around.   On the webpage, there is a green colored, vertical link on the right side of the page that reads "Email When Available".  You will receive an email when the jack has been made at which point you can place your order.
    Sharon
  • jgram2
    jgram2 Member Posts: 1,522
    For clarification, the removable jack products satisfy two needs-allowing easier removal of the jack wheel and opening some tailgates, right?
  • Tabaz
    Also allows better ground clearance when going over dips in parking lots or off-road.
  • jgram2
    Thanks OutbackAZ
    Yes Twograms.  I knew about the problem with the Jeep rear door clearance, but just found out about the clearance problem with the rear hatch of our Toyota Sienna minivan.
  • jgram2
    Oh no SAM, I was clarifying the issues for myself-still trying to decide if we should get one. With our small amount of travel, the only time we "scraped" was when we forgot to remove the jack wheel, but I can certainly see how that could be a problem in many scenarios. Thinking harder now. But nothing happens as Curly would say.
  • Newfisher
    Newfisher Member Posts: 105
    Can someone confirm that the poptab version specificaly designed for the T@bs is available, where to order etc?
  • Nomad
    Newfisher - Yes, it was custom designed specifically for T@Bs - I just tried to find it on the Teardrop Shop and couldn't - Could be that things are being switched around now that LG and PV have seperated. You could send Pop-T@b a private message, he makes them up as ordered.
  • Pop-T@B
    Pop-T@B Member Posts: 199
      Here is the link to the teardrop website for the removable Jack plate, it does show that they are sold out. I will contact them today to see if they need to get some on order, I will post an update later today on what I find out.
    https://teardropshop.com/collections/trailer-accessories/products/removeable-jack-plate?variant=16349316357
    Thanks!
