Many of us are guilty of not keeping up with our tire pressures, be it on vehicles or trailers. Well, we learned the hard way that "Oh, that tire looks OK" is not the best rule of thumb. While on a long Memorial Day weekend, we were all set up when my wife decided to check the pressure in our T@B tires. Both tires gauged at about 32 psi. Max pressure 44, so tires were a bit underinflated and we topped them to 40psi for trip home. About two hours down the road we felt something had changed. Towed behind an F150, the trailer does not even seem to be there. We pulled over and discovered that the passenger side tire had blown. The shredded tread swung like a scythe along the outside of the wheel well, ripping away the plastic "fender" and cracking the aft plastic trim piece. The side of the trailer was a mess of black smears. We made numerous discoveries. Our lug wrench was too big for the trailer nuts. The nuts holding the spare on were frozen. And we both need to workout more. Finally got blown tire off and spare on due to a Good Samaritan. Going to have remaining tire checked inside and out, but will still probably buy two new tires and keep them at correct pressure. Now we have to spend about $500 on new trim as well. Expensive mistake.
How old were the tires? Many replace tires after 4-5 years no matter what condition they are in.
Sterling, VA
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
You might want to weigh in on this recent thread: http://tab-rv.vanillaforums.com/discussion/comment/39457/#Comment_39457.
MOUSE-KE-T@B
Harvest, AL
I'd still be surprised if modest underinflation would be the root cause of such a failure. Furthermore, the maximum pressure indicated on the tire sidewall is often greater than the manufacturers recommended pressure listed on the vehicle sticker.
Not looking for an argument here--tire pressure, and tires in general, are one of those topics that nobody seems to agree on. Let's all just be glad that our T@Bs don't require motor oil! ;-)
MOUSE-KE-T@B
Harvest, AL
I'm going to see if the manufacturer of our new tires responds to my query.
Whenever I am hauling these trailers along the interstate system I am very aware of my speed as I know that the sidewalls will heat up at speeds in excess of 65 mph and obviously there is still heating that takes place regardless. Given the size of these trailers and accessories/gear we cram into them the added weight also comes into play, as do bad roads, road hazards, etc. Who's to say that this particular blowout wasn't a result of a shard of metal along the road or a jagged piece of concrete from the road? With the crumbling roads across the US it can happen at any moment and in any weather conditions.
I am not posting this to create an argument, nor to berate the unfortunate owner above, but believe that owners do need to read and heed the tire requirements listed on the sidewall of the tires (maximum inflation, etc.) and inflate accordingly. My tires are rated at 50 PSI (cold) and I inflated them to around 45 PSI prior to leaving on my recent trip out to Colorado in Mid-May. I noticed that the trailer seemed to start bouncing along an uneven stretch of the interstate down in Southern Michigan so I pulled off into a rest area, reduced the tire air pressures down to 40 PSI which took out the bounce and things calmed down and went well both to and from Colorado.
My point in the above is that inasmuch as the factory or Little Guy might recommend 35 PSI, the onus is on you as an owner to read/heed the tire rating listed on the sidewall, maintain your air pressure accordingly and if necessary, replace the stock tires as needed. This is no different than your personal vehicle and how you maintain it as conditions do change, tires do lose air pressure over the course of winter/season and it's important to keep your travel speed down too (trailer tires are rated at around 65 mph max) as we all want to get to and from our destinations safely and without endangering our personal safety, nor that of other motorists around us. If you are clipping along at 70 mph and above you are rolling the dice and could compromise the integrity of the tires... Face it, we've all done it, looked suddenly down at the odometer and felt that surge of fear/shock, knowing good and well we were traveling too fast and well above the rated 65 mph rating of the trailer tire.
Think about it next time out and do what needs to be done!
Picking up on what gulfarea said, now I'm curious... For those of you who have experienced a flat on your T@B, how and when did you determine it was flat?
So, no thumping, no loud noises, just a rumble that you wouldn't hear if the radio was turned up. I've had a flat in a car or a truck and I would have expected the thump, thump, but it was just a low rumble.
**Corrected, thanks, Chan
Nice driving Verna.
A fellow camper was following me, and she thought she would be finding Sunny Day and I in a mangled wreck.
I'm always amazed when something like that goes down and I've felt I'd just gone into 'autopilot' mode, and succeeded, thank goodness.
There's no time to think about what to do, you just do it.
I'm going with that until I hear otherwise from the factory.
When I got my first camper, my sister gave me my first gift-a Tire Pressure Gauge. Bear in mind, she is a horse drill team veteran who has pulled a gooseneck with horses all over the country. She said use it every time you pull out, on your first gas stop, and when you park. Me being the older sister internally said yeah, right. but time and time again, I am reminded of how important tire pressure is, and how much we can all take our tires for granted.
I have always followed her instructions religiously. Do you think I let her know that? Of course not, I am still the older sister.
