Ok, I try hard to keep our Tab's tongue weight at the conventional norm, using the "10% rule",
and it works well that way for towing stability.
All you folks that load up your tongue with the spare tire, the diamond plate tongue box, and the platform with lotsa stuff, what do you put in the
back of the Tab to balance it out?
Before we moved the tire to the tongue, i
t was pretty easy packing the Tab, and moving the load around inside to achieve @ 220# tongue weight.
Now that the tire is forward of the axle, I'll have around an 70# difference to adjust for, and I'm having a hard time imagining what we can put behind the axle that will compensate.
A whole lotta canned goods? (I hate canned food)
Chan - near Buffalo NY
This didn't answer your question except to say that you don't need as much weight to compensate as you might think, or that your calculations show. My opinion and others may vary.
The problem we've had all along is that the majority of the stowage space in the Tab is under the bed, and we usually keep the bed made up when we're traveling. Undoing the tucked in sheets et-al to access the storage is a PITA. Maybe I'll try to solve that access challenge for starters.
We use the under-seat space for large items that come out when we get to camp, and go back when we leave (e.g., awnings, folding chairs and tables, water jug, portable stove. Still might be a PITA for you though, if you're not making up the bed with each arrival. We mostly leave the bed up as well, but use light sleeping bags--less comfortable, but easy to toss aside for access to storage or conversion to benches.
I haven't weighed the tongue since relocating the spare, but plan to do so in the near future and will report back.
And, try some practice tows at your normal towing speed to see what works. You might like staple foods under the sofa (flour, pancake mix, syrup, etc.) or just spare stuff. As long as it fits through cargo door, it may find a home
It makes simple overnighters really easy, don't have to dig in the truck, just open the cargo door, pull out the electric cord and plug in.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
I was just looking the Tab over again for that cargo door idea.
Yeah we definitely need a simpler bedding system. It just might be the key. The cozy mattress pad/tucked-in-sheet routine should go. It's too much hassle, especially after a long day of driving, and a couple of glasses of wine...
On the LG Tab, the Alde takes up a lot of space on the driver's side. I don't know if it would be worth putting one in over there.
MOUSE-KE-T@B
Harvest, AL
Unfortunately, I did not weigh the tongue before relocating the spare, so I can't comment specifically on the impact of shifting that load to the front--at least not without some heady physics calculations, or wrestling the wheel back under the rear end. Neither of those are likely to happen... :-)
I'd need to calculate the weight based on how far from the axle the spare was/is, further complicated by the fact that it's vertical now, instead of horizontal. I know, I know, just measure from the center of the tire... Maybe. B-)
And then there's the additional mounting hardware.
Am I going overboard with this?!? Heh. You betcha!
Arghhhh! There's those heady physics equations.
I think it would be quicker to return the spare to its original mount. But, then...wouldn't it be cool to see how close your calculations come to your empirical measurements?! Let us know what you find out. :-)
My tongue weight comes to about 310... I was told that this was okay.
The only thing that I had to jettison was our tiremount and spare, which were about 50 pounds. I was hoping to keep this. Oh well,,
The only reason I am posting in this discussion was the idea of adding two of my wife's 20 pound weights to go under the backbench.. Maybe this is okay or would make a difference? Thoughts?
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
First. Why did you remove the front mount spare - - - space, weight, other?
If removed for weight - - - how did you make that decision?
Second. Assuming you are adding the two 20# weights because you wish to have them along not due to need to change tongue weight (trailer load distribution). Without the added 40# your 310# tongue weight is 13.4% of the loaded T@B GW. Well within the 10-15% range. Believe adding the 40# will have minor impact on tongue weight, new tongue weight will be around 303# or 12.8% of new T@B GW.
Disclaimer - - has been years since doing moments of force calculations - - use at own risk
Adventures: 51 Nights: 322 Towing Miles 41,200+
I removed the mount and spare because of the tongue weight concern. As you can see, without them, I'm at over 300 pounds. If I added them back, I'm probably going up to 375. We like the bike rack so it is going to stay. I thought I had to make a choice and keep the tongue weight lower. 10% of 2320 ( the weight of the trailer with bikes and rack) is of course 232 pounds. Now, if it is safe to add another 60 pounds of trailer weight, I'm all for it. Better than putting the spare in the front of the truckbed...
On the otherhand, I can always put the spare back when I'm not using the bikes.. It is an easy two bolt clamp setup...
I only mentioned the hand weights because at the beginning of this discussion, ChanW mentioned counter balancing the load and we had these weights.. Not that I want to lift them. I kinda figured that those weights would not do much.. I will of course study your chart....
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
just a reminder. Tongue weight at 10% is a minimum target so that it is not under weight. Fishtailing will mostly happen when the weight is to light. The real limitation for the tongue being over weight, is TV hitch load capacity. But as a rule of thumb, it should not exceed 15%. So you have fudge factor here, if your TV can deal with it. More than that, could also provoque stability issues if your TV is not able to support it.
The other thing about having to much weight, is the capacity of the trailer frame to support it. So again, the frame design should be made with the up tp 15% in wieght, but they would inclued a safety factor to this (and this is not official at all nore base on experience) of let say up to 25% before failure.
Hope this help with the reflexion on this topic.
have fun outhere!
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Suggest you redo your measurements as well as getting a feel for how the rig drives.
Can your local scale give you each axle weight instead of the combined TV weight? CAT Scale locations have three pads so you can get; steering, drive, trailer axle data.
Load the rig the way you really want it {assuming hand calculations suggest you are not over any axle rating} drive over to the scale and see what you weight. If you do boondocking and carry water don't forget to fill your water tank.
You can measure the tongue weight at home; before or after your scale trip.
You can also measure your truck fender well height with / without T@B to see how much rear drop & front lift the tongue weight is causing.
Now compare all axle data to axle GWR - - - everything have a nice margin? Steering axle not too light?
WilliamA
2017 T@G XL
So, if I understand this correctly, I should load up the truck as if we were going, and straddle two sections with the truck. Right? That gives more info, I suppose. Measuring fender well height is an interesting idea. We do notice during certain trips that the camper wheel can be more difficult to remove or replace.
T@bbey Road
Appleton, WI
All those little 'comfort additions' might just be adding up!
