But what the heck? Why is it so expensive? It doesn't look special to me. Before paying that much, I'd see if I could contact a friendly tech at Norcold and ask if any old 3A fuse would do.
Chan - near Buffalo NY 2014 S Maxx 2011 Tacoma 4cyl ... edit: 2022 Tacoma 6cyl - oh yeah! A_Little_T@b'll_Do_Ya
I do believe you can probably find a 3 amp fuse at just about any auto parts store. Just need to make sure on the length. That's where I went to get my spares for both my truck, and our WolfT@B.
2016 T@B MAX S-aka: WolfT@B TV: 2006 Chevy Avalanche LT Z71 aka: WhiteWolf, or 1972 Chevy Custom10 P/U aka: SnarlingWolf Spokane, Wa. Eric aka: Lone Wolf
There are variations, e.g. fast blow/slow blow.
I looked at the circuit diagram for my 3 way fridge and it appears that there are 3 fuses. The aforementioned 3amp fuse is part of the 120VAC heating circuit. There is also a 20amp in the 12VDC heating circuit, and a 1amp fuse that is part of the propane heating circuit. Alas there are no specs for any of them.
It it doesn't appear that the fuses are intended to be user serviceable parts. Has anyone here actually replaced one and had the fridge work after?
What's the difference between a fuse marked 3A/120v vs one marked 3A/24v? (Just as an example)
As far as I've ever known, amps is amps when it comes to fuses... No?
Here is a great resource for understanding fuses. Yes, you can substitute a 120v fuse in place of a 24v fuse, as long as all the other ratings are identical. But not the other way around.
Photomom, I haven't replaced them, but they are simple to remove, with a normal pop-in holder. You have to remove the stove top to access them.
There are fuses/breakers in the breaker box protecting the same things in the 3-way, so these are redundant, so to speak. Hopefully the ones in the breaker box blow first.
Without knowing anything other than what is shown in the circuit diagram, I am guessing that there would need to be a serious fault in the Fridge's A/C heater, DC heater, or propane lighter for the respective fuse to blow, and a replacement fuse would likely blow too. Therefore I'm not going to worry about getting these fuses. Coolers and ice are easy to come by.
I contacted tvformyrv.com who listed the fuse at @$2 plus shipping. I was asking if they could ship via USPS First Class postage, to save on shipping. This was his reply:
...stop in at any auto parts store and get a 3 amp fuse. It will work fine... No need to get a "Norcold" fuse, and no need to spend extra money shipping that particular fuse.
I thought that was pretty nice of him.
I tried to tell you! I usually get the packs that have a variety of all fuses large and small. Just handy to have them just in case.
I've had since April 13th when I first read about it. When I got it, I expected a gold one is a gold box. Bubble pack wrapped with a rubber band around it and not the pink anti-static bubble pack we had to use at the phone company. I won't get duped like that again!
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
Or here: http://www.tvformyrv.com/39-2234-norcold-fuse-3-amp-32v-or-less-61654622 (much more reasonable, except when you add shipping)
Just out of curiosity...
http://www.cooperindustries.com/content/public/en/bussmann/consumer/products/home_circuit_protectionproductsandaccessories/fuses/Glass_Ceramic.html
