If you are a newer owner, and you might not have needed to remove the propane tank, yet. I I know mine was not easy the first time. It required taking plyers to remove the wing nut and a socket to remove the bolt (9/16.) So, you might want to remove it at home with your full arsenal of tools. I had to use the socket to remove the bolt, and today. I think the weight of the tank and the bouncing of T@b must really tighten it up.
0 ·
Edited to add: This was a dealer install issue. Someone in a hurry.
Not that I think it would go anywhere, but I kinda like my flammable gasses to be well buckled in!
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
