Funnel For Fresh Water Tank
Ramrod
Member Posts: 164
Has anybody tried one of these silicone devices? 99 cents on Ebay. What can go wrong?
Ummmm...John and Henrietta, Late 2016 T@B S Max in Western New York
Yeaaaaaah........that's a......emmmmm......
Light a campfire and everyone's a storyteller. ~John Geddes
2017 t@b CS, silver with green trim.
TV: 2017 Honda Ridgeline. -
We have found having a screen built into the funnel is helpful. Just carrying a bucket of water from the spigot, we can get pine needles, etc in itJohn & Lisa, 2016 M@x S, Silver/Yellow, Hood Canal, WA, TV = 2008 Toyota FJ Cruiser
@Ramrod: if you INSIST on using the pictured device for refilling the fresh water tank, strongly consider bying a brand-new, unused one from a reputable source.
2014 T@B S-Maxx with 2014 Hyundai Santa Fe Sport Turbo, Atlanta, GA. -
Am I the only one that thinks this looks like a female urinal? Not sure I would buy it to use with fresh water!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Yes, that is what it is.SAM said:Am I the only one that thinks this looks like a female urinal? Not sure I would buy it to use with fresh water!Verna, Columbus, IN
It's called a Go-Girl
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart) -
any other advice on filling water tank without spilling would be appreciated.
Jaynie and Larry - Palo Alto, CA - 2015 T@B CS-S - Expedition EL - Nights spent in "T@b Spirit of Holly" 97
(9/22/19/ -
Well if filling the tank doesn't work out, at least everyone in camp can pee standing up
Tommy, good one!
Eric aka: Lone Wolf -
@Tommy - my recommendation to the girls would be "The Freshette". Rigid construction, extendable "hose" so you don't water your shoes/feet, compact and easy to clean.
Great for motorcycle riding with da boyz.
ok - but seriously when we fill water from 3 or 5 gallon container for dry camping we tend to spill some. What are other ways to add water without spilling? Any ideas are welcome
(9/22/19/ -
Look for a funnel for changing engine oil at an auto parts store. The funnel has an attached hose that you can stick into the filler neck.
If you fill from a hose there is a plastic tube you can screw onto the hose connector.John and Henrietta, Late 2016 T@B S Max in Western New York -
Why not use a plastic hose and create a siphon?
John2007 T@B
Rockford, IL
I managed to kludge a hose connector onto the nozzle of my 5 gal containers. With that, my regular clean water hose and the usual flexible nozzle, I can fill without any spilling. I do have to prop the tank up on a chair sitting on a table.
I like this for filling my water tank:
I haven’t used this yet but carry for potential use with spigots without threads, a I find in state and federal campgrounds:
Gil Butler, Folsom, CA, 2015 T@B M@XX CS - White with Yellow tim -
Multi tasking is all the vogue..but sanitize well between function changes."Not all those who wander are lost"- J. R. R. Tolkien
2014 T@B-S -
The Hopkins FloTool shaker siphon hose is amazing! As long as the water source is higher than the water destination, this thing quickly and easily transfers the water. I set my 5 gallon Jerry can on the Outback propane lid, put the brass end in the can, insert the plastic hose into the water inlet, shake a few times, and WaLa! Only $9 on Amazon. Also check out the YouTube videos on this product.2016 Outback 320
gilbutler - been using one of those since I got the T@B - works great with a hose or if your water jug has a std hose fitting.
I use a Reliance Hyderoller. 35 bucks at walmart. Holds 8 gallon and easy to wheel it back to the campsite when full of 64 lbs of water. Then a zodi pump pumps it into the T@B. Easy peasy2015 CS. Ford f150 v8. Southern california
I fill from a 5 gallon collapsable jug. I remove the spigot and pour away. Do I spill some, sure but it hasn't hurt the driveway yet. I do like the Camco adaptor for a hose that includes a shutoff. I think I will add that to my bucket for filling up from my potable hose at campsites. My camper is stored too far from the house to use my hose so at home I will continue to fill with my jug.2016 T@B M@X S grey/red 16 Foot Airstream, towed by 2014 Jeep Grand Cherokee V6 4x4, Central Connecticut
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
