I have moved my spare tire to the tongue
 and I am not quite sure about the finished product.  I used an Extreme Max Bolt On Spare Tire Carrier and two 2.5 inch muffler clamps.  Due to the width of the clamp there is minimal contact of the clamp to the jack.  Also I only tightened it enough to flatten the lock washers because I did not want to dent the jack tube.  Did I miss something?  Should I wrap the tube in some type of rubber to fill in the gap and get more purchase for the muffler clamp?
Thanks for any input.
Sterling, VA
"Growing old is mandatory. Growing up is optional."
I think almost anything would work, even a few wraps of duct tape (in your choice of color) if that's all you have lying around!
I have my tire sitting on some angle-iron cross bars that go across the tongue for support.
Sterling, VA
I noticed that the bolts that the spare would go on we're quite rusty already. Another reason not to keep the spare there.
I travel on some pretty rough roads getting to rivers and bottom out with the spare tire once in awhile. The clearance is very low when the tire is underneath.
I would recommend trying to take off the spare in ideal conditions. Then imagine road conditions. Add in some cold rain, snow or hail just for fun in your scenario! LOL.
Also, I had gone up a gas station entrance and heard it lightly scrape the spare when underneath. After the 2nd time I took out the T@B, that spare was off the bottom! I could see the scrapes. To be honest, I like the front position of the tire many people have set up. I need a little step to reach the lock for the tire on the Yakima rack. In addition, the front position adds a little tongue weight and can reduce a bit a sway if your TV can handle it (depending on how you pack). The tire weighs approx 40 lbs.
Knowing the structure of the roof though, makes me hesitate. Kinda like a cantilevered house - what's gonna hold it up, the foam roof and aluminum struts?
It sounds like the key is to get the rail "shoes" screwed securely into the camper's aluminum struts. Picking up on @Chan's concern, does anybody know if the Outback roofs are reinforced in any way compared to the standard T@Bs? I'm guessing not...
