Hose/pipe loose
Shhhhh......Mr_Mrs_Gnome said:@Verna, did you wave the magic wand???Verna, Columbus, IN
Beats havin'
her wave a broom around! Magic wands are MUCH nicer! 2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf1 -
My broom is disguised:
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2 -
YEEEEEEEEEEEE-ha
Eric aka: Lone Wolf0 -
And to keep this on topic - the pipes are stock
Edit: Oops, should show pipe side!
2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1 -
Ut oh, wrong thread!! (moved pict)2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1
Ratkity, too late, I think we already high-jacked this one!
If you're happy, we're happyDereco said:Given resolution (with thanks to PXlated, Verna et. al.), I am happy to have the thread hijacked. Anyone want to trailer to Newfoundland and buy a 2002 R1150RS??
. If you have time, photos of how the fix works would be helpful to others. A situation such as this has never been documented, and we had never seen this before. Thanks. Verna, Columbus, IN
Quick update: the wrong parts were sent out, a new fan kit for the square vent in front of the door. I assume address labels were reversed from a package intended for me. I will pop a quick note back to PV. But wow, one day courier service from there to Newfoundland. I am impressed!2
Update - PV has confirmed the new package was sent out last week, so all good.Dereco said:Quick update: the wrong parts were sent out, a new fan kit for the square vent in front of the door. I assume address labels were reversed from a package intended for me. I will pop a quick note back to PV. But wow, one day courier service from there to Newfoundland. I am impressed!
Another quick update: New vent kit arrived today, all looks good. The new hoses fit into the new black vent piece (that goes into the trailer wall from inside to out, see pics above).
Happy Camping, @Dereco! Promise us that if the CO detector chirps again, you will do an exhaustive search to find what it is telling you ( other than get out!).Verna, Columbus, IN
Dereco, Glad to hear you finally got the hose problem resolved. One question though... what caused the problem to begin with, or do you know?2016 T@B MAX S-aka: WolfT@B
No idea why the initial hose did not fit the opening, the new one does.ericnliz said:Dereco, Glad to hear you finally got the hose problem resolved. One question though... what caused the problem to begin with, or do you know?
Will do Verna!Verna said:Happy Camping, @Dereco! Promise us that if the CO detector chirps again, you will do an exhaustive search to find what it is telling you ( other than get out!).
Another quick update to say just I picked up the trailer, repair all done and new vent fan to boot. We head out this weekend so will update after the weekend if all works.
Cool - glad it got done and hope the camping goes well.0
Sadly, the fridge will still not work on propane. The hose is repaired, new vent, all that is good, but not on propane. Question, start a new thread with symptoms, etc or keep going here?0
Keep it here. It's your continued symptoms.
Do some searching and reading here. If you don't find a thread with your symptoms, check with your dealer. If still not fixed, check with Norcold. They are very particular about their service centers fixing the problems.Verna, Columbus, IN
Dereco, What happens when you try to light the fridge on propane? Sometimes you have to hold the "light" button down for about 15 to 20 seconds.2016 T@B MAX S-aka: WolfT@B
I have to hold my button down for up to a minute at times until the green light finally remains solid.Verna, Columbus, IN
I'm surprised the dealer didn't make sure the fridge worked before returning it to you. Does the stove top light? Just curious because I always start the stove top before lighting my fridge to make sure the propane flow is there. I've had to try to start mine more than once at times, other times it starts right up. No rhyme or reason, just does, or doesn't.2016 T@B MAX S-aka: WolfT@B
Thanks Verna and Ericnliz. So, here is what I happens:
- I hear clicking, very faintly, from outside even more so, but still faint, when the button is not depressed; sometimes when depressed, but not like before when it worked;
- I have held it in for the extended periods as recommended, but no go. I used to her the pilot catching before, the green light on and off and then finally on (when it worked);
- I removed the cooktop (yes, it works) and looked, and can see a slight sparking to the right, directly inside or behind where the green light wiring goes. I am attaching a picture that shows the spark. This is taken from an angle, looking out over the top of the fridge (one can see the vent on the side of the trailer towards the top of the picture).
- I called the trailer shop, they said they just installed the parts but did not test the fridge to be sure it worked. Doh!;
- I was on shore power, at the same time (so no low voltage problem...); and
- I have checked the Forum for "clicking," it may be a thermocoupler issue?
I just arrived at a campsite and turned my vehicle off. Verna was there to greet me. She noticed a clicking noise coming from the front of my trailer. I was traveling with the Norcold on propane. Apparently, the flame went out and the Norcold kept attempting to relight. So the clicking noise may mean you're not getting any/enough propane to the unit. Regarding problems with starting the Norcold on propane, I always light a stove burner first and wait about 20 seconds. Turn it off and then move the Norcold temp dial to the 6 o'clock position. Press the ignition button and hold for one full minute after the green light comes on. Then slowly release the button. Seems to work every time. Also check the fuses and thermocouple fitting on top of the frig.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
The "clicking" noise you hear is the fridge trying to light . Like OutbackAZ said, hold the button down, and slowly release it. Also ditto on the thermocoupler fitting, lots of loose ones. If all else fails, call, or write PV, or maybe someone else has an idea. Sounds like you're trying all the right things to no avail. Good luck, and please let us know what you find out. I'm still flabbergasted to the fact the dealer didn't confirm the fridge worked while they had it in their possession.2016 T@B MAX S-aka: WolfT@B
If you hear clicking, and see sparking, one thing to check would be the distance between the electrode and the burner. Per the service manual the distance should be 1/16" min and 1/8" max.John and Henrietta, Late 2016 T@B S Max in Western New York0
The spark your seeing is not right. If its sparking where you can see it in the general wiring it is not sparking at the burner. I can't quite see clearly the two objects the spark is jumping between in the photo. But it looks like the insulation on the white wire might be compromised. You might try several wraps of good electrical tape around it and rerouting it as far from what might be the High Voltage Coil to its left. If your not comfortable with that I would take it to a professional.
I work for a company that builds ignition wiring and components for natural gas engines. Frequently trouble shoot this sort of failure.Jupiter, Florida~T@B 400, with 2018 Toyota 4Runner
SweetlyHome said:The spark your seeing is not right. If its sparking where you can see it in the general wiring it is not sparking at the burner. I can't quite see clearly the two objects the spark is jumping between in the photo. But it looks like the insulation on the white wire might be compromised. You might try several wraps of good electrical tape around it and rerouting it as far from what might be the High Voltage Coil to its left. If your not comfortable with that I would take it to a professional.
Thanks again to all for feedback.
To Sweetly Home, the photo might be misleading, the sparking is down at the level of the top of the fridge, alongside the two blue 'things' indicated by the longer red arrow. The area is all contained in a small black plastic (?) tray, held in place by the screw indicated by smaller arrow.
Question: does some part of that constitute the thermocoupler? Or is the part in the 2nd picture?
I think the "sparking" described is an indicator of some sort on the circuit board. Mine does the same thing.
About half the time, I also have trouble lighting my fridge on propane. (Yes, I run the stove first.) The light will come on and then go right out again, even as I continue to hold down the button. After a couple rounds of this, it won't light at all. Cursing does not help, but walking away does. In all cases, the fridge would light without any drama after sitting a couple hours (or in one instance, overnight). Once it starts, it runs fine.
I might check that distance between the electrode, and the burner. Thanks for pointing that out, Photomom.
2015 Nissan Frontier SV V6 4x40
- 964 Air Conditioning & Refrigeration
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 920 Tips & Tricks
