Possible solution for non-priming water pump?
ChrisKChrisK Member Posts: 280
We have a 2014 S-Max and the water pump this trip has been failing to prime on its own. Just runs but won't prime. Tried turning on the faucet and still nothing. What worked is holding open the toilet flush valve. At first, you get the residual water left in the system, then air for a number of seconds, then the pump started priming. No problems after that. Your mileage may vary but it has worked twice for me so far.
2014 T@b S Max AKA T@dpole
