Water Line Blow-Out vs RV Antifreeze...Experts please weigh in!
If you use an air compressor to blow all of the water out of your lines, why would you have to add RV antifreeze to fill all the tubing?
Shouldn't it be enough to do one or the other, but not necessary to do both?
(I know that you do need to put some RV antifreeze in the drains for the shower, sink, toilet, and the gray water and black water tanks.)
Cheryl, 2014 Jeep Grand Cherokee Diesel, 2015 T@b S Maxx (T@bitha)
0 ·
- No antifreeze, or water, in the Alde (or any of the hot water lines as a consequence).
- The fresh water tank, cold lines, and importantly the electric water pump, all filled up with antifreeze.
- Some antifreeze in all the drain traps
- Some antifreeze in all 3 of the tanks (fresh, grey, black)
By the way, you can absolutely run the Alde heat with its water tank dry. The boiler is surrounded first by the heating jacket that is filled with glycol.
I would have been satisfied with just blowing the system out with air, but that leaves water in the electric water pump and lines connected to it. That pump would not do well in a freeze.
Hope that helps! And for goodness sake if you think what I did missed something or is just dumb, let me know!
I use the blow out method because it is easy and because we camp year round, so I actually end up winterizing the T@Bpole several times each winter, after each trip. I will do the first winterization in a few weeks after a weekend trip to Hershey, then again after a trip in December, and finally after a trip (to Florida) in January, so it saves a lot of effort to not have to clean the system of antifreeze each time.
I have to find the thread, but I did post some pictures of the process.
Sterling, VA
FYI, you can use a bike pump and blow out plug to clear tour lines, too. I just did that today because my air compressor did not work and is at the factory repair center.
I did both because we are expecting a cold and snowy winter this year. I might de-winterize once the compressor is back and just blow out the lines.
Start by draining your hot water heater. I have an electric one under the sink, which I can connect a hose to to drain. I don't know the draining procedures for the Alde heaters. Also open the fresh water tank's valve up and drain that.
Put the plug in your city water hook up and set the compressor to about 25psi. Make sure to open all faucets, including the outdoor shower (we didn't use it, but it still had water in the lines) and run the water pump for about 30 seconds.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
This is what I am taking away from this thread.
The Alde does not need water to run the heater.
IF I plan to use the Alde (heater only, not hot water) during months when temps may fall below freezing, then
1) drain all water lines and blow them out using the compressor
2) pour antifreeze into all drain traps and fresh water tank (do not pump antifreeze into the water lines)
IF I do NOT plan to use the Alde, it is OK to add antifreeze to the water lines (in addition to all traps).
I thought I had this all figured out, but my head is swimming from information overload on winterizing the T@B. It's a bit overwhelming trying to put all the pieces together. Is my summary above correct?
2014 T@B S M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
"Take only pictures, leave only footprints."
