Does anyone lube their hitch ball before hooking up the trailer? I smear a very light coat of Mobil 1 chassis grease (the red stuff) on the ball when towing then wipe it off with a paper towel after unhooking at the day's destination, also wipe the inside of the ALKO hitch. What do you do?
John & Cheryl
2018 Chevy Colorado V-6
Edmond, OK
1 ·
Sterling, VA
Good idea! Will try it, would be easier than carrying a small tube of lube.
Thanks.
Edmond, OK
If we're staying for more than a day I remove the ball mount and stow it with a paper towel rubber banded over the ball. Otherwise it gets wiped clean.
Also use the spray silicone on the corner steady's threaded rods as grease tends to attract dirt.
WD-40 is not a lubricant, it was designed for removing water/moisture. WD stands for water displacement.
T@BMahal
'04 #100
40 attempts to get the formula right indeed, not many products are that honest about the research and development.
T@BMahal
'04 #100
2014 T@B CS Maxx
Martha Lake, WA
Here you go . . .
http://www.andersenhitches.com/Products/3662--2-greaseless-hardball.aspx
IMHO steel on steel with all the movement in towing is not a good idea. The wear is to the inside of the coupler on the trailer if not greased.
T@BMahal
'04 #100
No more mess! Love it.
There seems to be good arguments either way, and no real consensus on what is best or necessary. Given that, I opt for the approach that involves the least hassle and mess.
I agree that the grease will attract dirt that is abrasive, and you are correct that their is no real consensus on what is best.
Each of us must decide what we think is a reasonable path to follow.
I chose the grease-less ball approach and still use a lubricant to make it slippery.
T@BMahal
'04 #100
Sterling, VA
I'm going to use the same stuff except the CRC brand from WalMart in a red/white can.
As far as accumulating grit, that is why I wipe the ball and hitch periodically, but really don't seem to observe much in the way of dirt/filth. So I'll continue with the spray lube rather than the chassis grease for now.
Edmond, OK
The issue with a hard to uncouple trailer is usually because the TV and trailer are at different angles. I have an '04 DM with the Alco frame and very rarely have an issue with not being able to uncouple.
Nathan,
Yes, that is a different product and will work very well as Lithium is much better than axle grease.
T@BMahal
'04 #100
I have heard a rumor that PV had a bad batch of couplers, they were not quite an actual 2" coupler ! Do not know the details, but PV has replaced some.
Homebodyatheart,
I cannot seem to find a 2" one googleizing, the smaller 1 7/8" is available - but that does us no good ! ! ! Sorry if I started something that is no longer available.
T@BMahal
'04 #100
