Well that was easy- got out the truck's jack, placed it under the tongue and with a few turns, it was high enough to put the wheel back on. Now I wish I had thought of that (but kudos goes to the fine folks on this forum).
Simply lift the tongue with the tongue Jack high enough then lower your front stabilizers. They are more than able to support the front indefinitely or while changing the dolly wheel. Stabilizers can not be used for lifting just for supporting. They can not lift because the foot pad moves in an arch and must move horizontaly as well as vertically when lowered.
Simply lift the tongue with the tongue Jack high enough then lower your front stabilizers. They are more than able to support the front indefinitely or while changing the dolly wheel. Stabilizers can not be used for lifting just for supporting. They can not lift because the foot pad moves in an arch and must move horizontaly as well as vertically when lowered."
Best entry yet in this series! Physics and mechanics will always trump over all else! I too have a pad to replace the wheel as I have found many sites where the tongue needed to be low to get the rig level, especially on a sandy soil site where a wheel wouldn't work. This was the case when we parked the T@B at Shadock Island State Park in NY on the Hudson River for a week this past July on a trip east.
We haven't used the jack wheel since the first trip, more trouble than it is worth. A piece of board works great and doesn't make a divot in our driveway.
I've found a few places I can't get the front end low enough with the wheel on so I almost exclusively use the foot.
@mickietucs - Also have this issue while camping and parking at my house. Just realized a foot would help both at home and when leveling. Searched for "foot pad" and found this post. Looks like you have the surge brakes (not electric) - is there any issue with the foot being too low (can you retract it all the way and not have front of tongue touch ground?)
2013 MAXX T@B towed by a 2015 Volvo S60 5 CYL AWD Sedan Seattle, WA -> Palm Springs, CA
I have elec brakes. I do have a foot and use it 99% of the time. I like the wheel if I needed to move the trailer around by hand but I'm usually on dirt or gravel. PXL - I don't know how you do it as I know you're mostly on dirt too.
Don't know how I do what exactly. For the wheel, I have a leveling pad that's smooth on one side and it's about 18" square - found it on the road, think it's a big rig pad. Have seen them in RV supply places. Allows me to move the wheel around a bit when I'm on sand/gravel.
If you had 2 of those you could move it almost anywhere. I like the idea. I have had problems on soft terrain, and that's a good solution. Flat and easy to store.
Actually, I think it a stabilizer pad for a big rig - found it in the middle of the road when leaving a campground.
