Are you using accessing the forum from a desktop, tablet, or smartphone?Twojgrams said:Searching on my browser with a phrase has been largely unsuccessful for results from this forum. Am I missing something obvious?
What are some example phrases you tried searching for on your iPad (Safari) that did not locate what you wanted on the forum?Twojgrams said:I use an iPad 98% of the time.
You and @Photomom might be in competition for yellow star accumulations!!Twojgrams said:@ChanW-instapaper sounds interesting-I'll give it a looksee. Pxlated, will check out pocket. TabberJohn, I use an iPad 98% of the time. Thanks for those suggestions. And LauraRey, I have been too enthusiastic with the yellow star!
The current forum is an exact string search only. For example, try these text searches entered without quotes --
"bupkis" will locate several entries in this thread.
"returns bupkis" will only locate entries with that exact phrase.
"returned bupkis" will only locate entries with that exact phrase.
This explains why searching for "winterize" locates entries with "winterize" or "winterize(d)" while searching for "winterizing" find other posts entirely.
Bottom line: Don't try using the default forum search to locate anything other than a single word or exact phrase. Single words are also best limited to the shortest common letters possible. For example, "winteriz" will locate posts for all three possible entries (winterize, winterized, winterizing).
And/Or logic or text phrases ONLY WORK if you use your browser's search engine instead.
For that use the format "xxx site:http://tab-rv.vanillaforums.com" where xxx is your text string.
For example, enter "winterize or winterizing site:http://tab-rv.vanillaforums.com" into your browser's search bar to locate all possible articles related to winterizing.
Enter "winterize and Alde site:http://tab-rv.vanillaforums.com" to locate articles that include both terms.
If you try entering ""winterize and Alde" into the default forum search box in upper right you'll get bupkis.
