Recommendations on Spare Tire bracket for Mounting on Tongue
LauraRey
LauraRey Member Posts: 338
Hi folks,
Now that I've upgraded my tow vehicle, I want to mount the tire on the tongue.  I've seen several examples in the forum. Do you all have a specific mounting bracket you recommend?  Or ones that I should definitely avoid?
Thanks in advance,
  Laura
  • Photomom
    Photomom Member Posts: 2,217
  • Nomad
    Nomad Member Posts: 7,209
    I have this one - Been good and solid for 2 1/2 years - Got it at a boat dealer. Seems all the boat trailers in MN (Land of 10,000 Lakes) use these...
  • Me_and_My_Dog
    Me_and_My_Dog Member Posts: 184
    edited February 2017
    Following this thread. I am interested in moving the spare to create more clearance underneath, and to make the spare more accessible. This looks very doable. Anyone have pictures of the spare moved up front?
    I'm torn about muddying up the sleek aesthetic of my tongue area! Maybe my priorities are skewed?
    Looks like there is another thread here: http://tab-rv.vanillaforums.com/discussion/1289/where-do-you-store-the-spare-tire
    Katt and Miss Cannoli the Zen Dog
    2008 DM T@DA — Towed by 2014 Dodge Durango — Full time since 6/29/17
    "Travels With The Tiny"
    I took the jack post mounting approach. I also thought it would look less than appealing, but having done it I kinda' like it. YMMV.
  • Nomad
    Me_and_My_Dog - I'm sure that if you have a flat and have to crawl under the T@B, you "will" realize then that your priorities were skewed - Guaranteed - Especially if it's raining :-)
  • Me_and_My_Dog
    Yes this looks cool. I agree. I have an older DM T@B with the european type of jack, so this wouldn't work. Thank you for the picture!!!!
  • Me_and_My_Dog
    Yes, I'm trying to look into my crystal ball and avoid the hand to forehead scenario when I'm on the side of the road with no cell service and the big rigs screaming by and it's raining and my dog is hungry and I'm in my best shoes. Better prepare for that. Thanks!
  • Me_and_My_Dog
    I saw this on the T@DA, T@B & T@G Camper Trailer Owners FB page. It seems like this spare rides kinda low.
  • Me_and_My_Dog
    This is the look I'm looking for. Just like ScottG's attractive setup, but attached to the frame rather than the jack. This looks custom rather than an off-the-shelf bracket.
  • reedd
    reedd Member Posts: 61
    I'd seen this thread a while back and really liked the idea of this mount.
    http://tab-rv.vanillaforums.com/discussion/comment/33636/#Comment_33636
    Here is the link to the Croft site:  https://www.crofttrailer.com/stctm-croft-tongue-mount-spare-tire-carrier-weld-on#page=page-1
    Deb - 2017 T@B U-basic Outback silver/silver  D@mselfly
    2001 Toyota Tacoma 4WD New Mexico
  • reedd
    ScottG, where did you get this and what's the brand?  Thanks!
  • db_cooper
    db_cooper Member Posts: 749
    Has anyone put the jack mounted tire on the Outback?  I'd like to order one, but can't get to the trailer right now.
  • Me_and_My_Dog
    Found what I want on Amazon, but the company no longer exists, aparently. https://www.amazon.com/T-B-TAB-Tire-Carrier/dp/B004WGMT0M/ref=cm_rdp_product
    Next step: Look for local welder to fabricate.
  • Homebodyatheart
    Some here have found them at marine supply stores. I look forwardto pics when you decide. It's on my mod wish list.
    I ordered the "Tow Tuff TTF-0345TC Universal Spare Tire Carrier with Lock" from Amazon, but I've seen several similar contraptions from different companies.
    The U-bolts are garden variety items from any hardware store. I don't recall the size, but it wasn't too hard to figure out. Though probably unnecessary, I slipped a bit of rubber casing from an electrical cable around the U-bolts so they would fit snugly and have a little more grip.
  • elgolfo
    elgolfo Member Posts: 22
    I second what "Me and My Dog" posted,would love to put it on my 2007 t@b!
    2007 t@b,no mods at all,2013 Jeep jk 4 door,Sedona,Az and El Golfo de Santa Clara,Sonora,Mexico,
    Tim & Jill
  • Ron
    Ron Member Posts: 137
    I just toured the new 400.  They have mounted the spare tire under the propane tank.  The wheel lowers with a mechanism like you fine under a pickup truck now.  Might be enough room if you combine both drains to the sewer drain to do this on the tab.  Might be worth taking some measurements.
  • Playc
    Playc Member Posts: 234
    Amazon link seems to be a good solution.  Too bad it's no longer available.  Any luck finding something similar or what is another way to do it?
    2015 S Sofitel, Austin/Houston
  • Playc
    Would also like to see pics as I need to make the mod so spare wont scratch the ground when up/down slopes
  • Homebodyatheart
  • Playc
    Seems easy to do.  Anyone has success on this one?
  • dmerzbac
    dmerzbac Member Posts: 289
    I think PXLated  mounted his spare similar to that one. I bought bracket like that, but decided to mount the tire behind the tongue jack. This is the bracket I bought:
    https://www.amazon.com/dp/B00J06MCE2/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=32TOOVRP6ECXI&coliid=I3QZKWSWLFBVGH
    2017 T@b 320 - 'Smokey'  2017 Toyota Tacoma TRD Sport - 'B@ndit'
    Dave - Tuscaloosa, Al
  • Playc
    Thanks for the link.  Bought and installed.  Will be on trip next week.
    Does it look ok and safe?  Will it interfere turnings?
  • Cyclonic
    Cyclonic Member Posts: 1,232
    And it is always raining when you have to change a flat!
    Sterling, VA
  • Playc
    Decided to move my spare into TV (as it has the space)... probably the SAFE and EASY way.  Just trying hard and best to prevent any issue, esp, our big trip to Yellowstone late May.
  • Homebodyatheart
    ScottG, I have to comment...nice tow "vehicle" chained to your T@B! Keeps them both from wandering off I bet!  :-)
    Yeah, I laugh at all you people and your silly concerns about tow ratings, horsepower, and electric brakes!  ;-)
  • db_cooper
      Just make sure it's strapped in good. Knew a guy that rolled his SUV and ended up in the cargo area being battered by a loose tire.
  • Ratkity
    Ratkity Member Posts: 3,770
    Bahahahahaha @ScottG. T@B, the touring bike version. Runs on protein bars, gatorade and someone using a whip to make you pass that 18-wheeler!! :lol:
  • Playc
    Hi ScottG - Like your approach.  Does it interfere with the Protane box?  Would you please post a link for the mounting hardware?  Thanks.
