Recommendations on Spare Tire bracket for Mounting on Tongue
LauraRey
Member Posts: 338
Hi folks,
Now that I've upgraded my tow vehicle, I want to mount the tire on the tongue. I've seen several examples in the forum. Do you all have a specific mounting bracket you recommend? Or ones that I should definitely avoid?
Thanks in advance,
Laura
Thanks in advance,
Laura
Red and White, 2017 Max S being towed by a 2014 Honda Ridgeline. Hello Mountains!
This is the one we have mounted to the jack post. https://www.amazon.com/gp/product/B00RJKB2FQ/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
John and Henrietta, Late 2016 T@B S Max in Western New York1 -
I have this one - Been good and solid for 2 1/2 years - Got it at a boat dealer. Seems all the boat trailers in MN (Land of 10,000 Lakes) use these...
Following this thread. I am interested in moving the spare to create more clearance underneath, and to make the spare more accessible. This looks very doable. Anyone have pictures of the spare moved up front?
I'm torn about muddying up the sleek aesthetic of my tongue area! Maybe my priorities are skewed?
Looks like there is another thread here: http://tab-rv.vanillaforums.com/discussion/1289/where-do-you-store-the-spare-tireKatt and Miss Cannoli the Zen Dog
2008 DM T@DA — Towed by 2014 Dodge Durango — Full time since 6/29/17
"Travels With The Tiny"0 -
I took the jack post mounting approach. I also thought it would look less than appealing, but having done it I kinda' like it. YMMV.Me_and_My_Dog said:...
Me_and_My_Dog - I'm sure that if you have a flat and have to crawl under the T@B, you "will" realize then that your priorities were skewed - Guaranteed - Especially if it's raining :-)3
Yes this looks cool. I agree. I have an older DM T@B with the european type of jack, so this wouldn't work. Thank you for the picture!!!!ScottG said:
Yes, I'm trying to look into my crystal ball and avoid the hand to forehead scenario when I'm on the side of the road with no cell service and the big rigs screaming by and it's raining and my dog is hungry and I'm in my best shoes. Better prepare for that. Thanks!PXLated said:Me_and_My_Dog - I'm sure that if you have a flat and have to crawl under the T@B, you "will" realize then that your priorities were skewed - Guaranteed - Especially if it's raining :-)Katt and Miss Cannoli the Zen Dog
I saw this on the T@DA, T@B & T@G Camper Trailer Owners FB page. It seems like this spare rides kinda low.
This is the look I'm looking for. Just like ScottG's attractive setup, but attached to the frame rather than the jack. This looks custom rather than an off-the-shelf bracket.Katt and Miss Cannoli the Zen Dog
I'd seen this thread a while back and really liked the idea of this mount.
http://tab-rv.vanillaforums.com/discussion/comment/33636/#Comment_33636
Here is the link to the Croft site: https://www.crofttrailer.com/stctm-croft-tongue-mount-spare-tire-carrier-weld-on#page=page-1Deb - 2017 T@B U-basic Outback silver/silver D@mselfly
2001 Toyota Tacoma 4WD New Mexico0 -
Has anyone put the jack mounted tire on the Outback? I'd like to order one, but can't get to the trailer right now.
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6200 -
Found what I want on Amazon, but the company no longer exists, aparently. https://www.amazon.com/T-B-TAB-Tire-Carrier/dp/B004WGMT0M/ref=cm_rdp_product
Next step: Look for local welder to fabricate.Katt and Miss Cannoli the Zen Dog
Some here have found them at marine supply stores. I look forwardto pics when you decide. It's on my mod wish list.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
I ordered the "Tow Tuff TTF-0345TC Universal Spare Tire Carrier with Lock" from Amazon, but I've seen several similar contraptions from different companies.reedd said:ScottG, where did you get this and what's the brand? Thanks!
The U-bolts are garden variety items from any hardware store. I don't recall the size, but it wasn't too hard to figure out. Though probably unnecessary, I slipped a bit of rubber casing from an electrical cable around the U-bolts so they would fit snugly and have a little more grip.
I second what "Me and My Dog" posted,would love to put it on my 2007 t@b!2007 t@b,no mods at all,2013 Jeep jk 4 door,Sedona,Az and El Golfo de Santa Clara,Sonora,Mexico,
Tim & Jill0 -
I just toured the new 400. They have mounted the spare tire under the propane tank. The wheel lowers with a mechanism like you fine under a pickup truck now. Might be enough room if you combine both drains to the sewer drain to do this on the tab. Might be worth taking some measurements.2016 T@B MaxS, 2018 Jeep Rubicon 4dr, Rural Scottsdale, Az.0
Me_and_My_Dog said:Found what I want on Amazon, but the company no longer exists, aparently. https://www.amazon.com/T-B-TAB-Tire-Carrier/dp/B004WGMT0M/ref=cm_rdp_product
Amazon link seems to be a good solution. Too bad it's no longer available. Any luck finding something similar or what is another way to do it?2015 S Sofitel, Austin/Houston0 -
Homebodyatheart said:Some here have found them at marine supply stores. I look forwardto pics when you decide. It's on my mod wish list.
Would also like to see pics as I need to make the mod so spare wont scratch the ground when up/down slopes2015 S Sofitel, Austin/Houston0 -
I've also had this one bookmarked:
https://www.lowes.com/pd/Carry-On-Trailer-Spare-Tire-Wheel-Carrier/31205552017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
Seems easy to do. Anyone has success on this one?Homebodyatheart said:I've also had this one bookmarked:
https://www.lowes.com/pd/Carry-On-Trailer-Spare-Tire-Wheel-Carrier/31205552015 S Sofitel, Austin/Houston0 -
I think PXLated mounted his spare similar to that one. I bought bracket like that, but decided to mount the tire behind the tongue jack. This is the bracket I bought:
https://www.amazon.com/dp/B00J06MCE2/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=32TOOVRP6ECXI&coliid=I3QZKWSWLFBVGH
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
Thanks for the link. Bought and installed. Will be on trip next week.Homebodyatheart said:I've also had this one bookmarked:
Does it look ok and safe? Will it interfere turnings?2015 S Sofitel, Austin/Houston0 -
And it is always raining when you have to change a flat!PXLated said:Me_and_My_Dog - I'm sure that if you have a flat and have to crawl under the T@B, you "will" realize then that your priorities were skewed - Guaranteed - Especially if it's raining :-)
Sterling, VA0 -
Decided to move my spare into TV (as it has the space)... probably the SAFE and EASY way. Just trying hard and best to prevent any issue, esp, our big trip to Yellowstone late May.2015 S Sofitel, Austin/Houston0
ScottG, I have to comment...nice tow "vehicle" chained to your T@B! Keeps them both from wandering off I bet! :-)2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
Yeah, I laugh at all you people and your silly concerns about tow ratings, horsepower, and electric brakes! ;-)Homebodyatheart said:ScottG, I have to comment...nice tow "vehicle" chained to your T@B! Keeps them both from wandering off I bet! :-)
2015 Nissan Frontier SV V6 4x44 -
Just make sure it's strapped in good. Knew a guy that rolled his SUV and ended up in the cargo area being battered by a loose tire.Playc said:Decided to move my spare into TV (as it has the space)... probably the SAFE and EASY way. Just trying hard and best to prevent any issue, esp, our big trip to Yellowstone late May.
2022 Ford F350 Tremor | 2022 Cirrus 6201 -
Hi ScottG - Like your approach. Does it interfere with the Protane box? Would you please post a link for the mounting hardware? Thanks.ScottG said:
