Anyone know a rough idea of the cost to wire my car for my T@B's lights and brake system?
luvmytab
Member Posts: 66
Just bought a new car so have to have it done all over again
Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
What make/model? Doest it have the factory tow package and the minimal 4-pin plug? Need a new brake controller as well or just the wiring?0
When I bought my T@G (June, 13), the dealer installed the hitch and wiring for around $400.00 just had the van done for the T@B for a little under $600.00 (Oct, 16). These prices were turn key including all parts and labor. I could have saved over half if I purchased the parts and did the work myself, but there are some things I prefer to leave to the professionals. *The T@B needed the brake controller whereas the T@G did not. I live in Western Pa, prices may vary where you live. Best of luck!1
Hmmmm - Mine was only around $150-175 ... That's why I asked the questions, depends on where you're starting from.0
thanks everyone...mine will be 223.00 plus tax for the brake controller on my 2016 4runner...already has the wiring for lightsBarbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner0
Make sure they add a charge line for the battery. They do not do this as a routine unless you specify.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
10 or 8 guage wire for the charge line?0
8 will give you a higher rate of charge while driving, but 10 is also acceptable if the costs are a concern.
Make sure they run the wire so it's nowhere near the exhaust system - Uhaul strung mine too close and it finally melted the insulation and shorted out.0
We had uhaul install the hitch and the 7 pin wiring on a 2013 Subaru Outback=$389
Then our local car mechanic install the electric brake for $485. I think it may be on the high side for price but worth it to me to know it was done correctly and backed by warranty.0 -
People have mixed experiences with UHaul. I had a good one but others have reported bad ones. When I bought the T@b my RV dealer did it all for $150. I would try to negotiate the wiring as part of the sale.Joan said:We had uhaul install the hitch and the 7 pin wiring on a 2013 Subaru Outback=$389
