Anyone know a rough idea of the cost to wire my car for my T@B's lights and brake system?
Just bought a new car so have to have it done all over again
Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
  • Nomad
    Nomad Member Posts: 7,209
    What make/model? Doest it have the factory tow package and the minimal 4-pin plug? Need a new brake controller as well or just the wiring?
  • Kurt_SueAnn
    Kurt_SueAnn Member Posts: 10
    When I bought my T@G (June, 13), the dealer installed the hitch and wiring for around $400.00 just had the van done for the T@B for a little under $600.00 (Oct, 16). These prices were turn key including all parts and labor. I could have saved over half if I purchased the parts and did the work myself, but there are some things I prefer to leave to the professionals. *The T@B needed the brake controller whereas the T@G did not. I live in Western Pa, prices may vary where you live. Best of luck!
  • Nomad
    Hmmmm - Mine was only around $150-175 ... That's why I asked the questions, depends on where you're starting from.
  • luvmytab
    luvmytab Member Posts: 66
    thanks everyone...mine will be 223.00 plus tax for the brake controller on my 2016 4runner...already has the wiring for lights
    Make sure they add a charge line for the battery.  They do not do this as a routine unless you specify.
  • Rolltide82
    Rolltide82 Member Posts: 89
    10 or 8 guage wire for the charge line?
  • wizard1880
    wizard1880 Member Posts: 442
    8 will give you a higher rate of charge while driving, but 10 is also acceptable if the costs are a concern.
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
  • Nomad
    Make sure they run the wire so it's nowhere near the exhaust system - Uhaul strung mine too close and it finally melted the insulation and shorted out.
  • Joan
    Joan Member Posts: 11
    We had uhaul install the hitch and the 7 pin wiring on a 2013 Subaru Outback=$389
    Then our local car mechanic install the electric brake for $485. I think it may be on the high side for price but worth it to me to know it was done correctly and backed by warranty.
  • jkjenn
    jkjenn Member Posts: 6,425
    People have mixed experiences with UHaul. I had a good one but others have reported bad ones. When I bought the T@b my RV dealer did it all for $150. I would try to negotiate the wiring as part of the sale.
