Alde on shore power?
Our Alde doesnt seem to work when its plugged in in our driveway! Anyone have any thoughts on why not?
  • Nomad
    Nomad Member Posts: 7,209
    Have you checked your circuit breakers and the little red button on the interior outlet.
    If they are all ok...Do you have the analog or digital thermostat and what setting do you have it set at.
  • jkjenn
    jkjenn Member Posts: 6,425
    Also possible that you blew a fuse in the Alde or tripped a breaker in your house. Out if curiosity, how long has it been on?
  • Ratkity
    Ratkity Member Posts: 3,770
    Under the seat where the Alde resides, check the plug. Sometimes it sneaks out of the socket.
  • Smullis7
    Smullis7 Member Posts: 221
    Also if you have the digital controller, make sure you have the electric setting turned on.  I don't have the ability to upload a photo right now, but it should be on the first menu screen toward the bottom above the propane setting.
    ScottG Administrator Posts: 5,693
    As you have probably already deduced from the comments thus far, any one of a dozen plus things could be to blame for a non-functioning Alde...
    Another thing to consider that the Alde circuitry still needs 12V power even when you are running on house current. If your converter isn't working, or if the 12V blade fuse to the Alde is blown, nothing will work. Same goes for the two hidden fuses to which jkjenn alluded--they are located on the Alde itself near where the 12V line from the converter attaches.
  • Tabaz
    Tabaz Member Posts: 2,420
    Also check out "Fuses for Newbies."
  • sugarloafer
    sugarloafer Member Posts: 10
    Thanks for all the help! Ratkity wins! 'Somehow' that plug actually did sneak out of its socket! Its 75 in there now. Thank you all!
  • Ratkity
    Dem sneaky plugs! This time I can't be blamed for tripping over it and pulling it out. LOL
  • ericnliz
    ericnliz Member Posts: 4,437
    Ratkity, No you just used to blame Harvey for that one! ;)
  • Ratkity
    LOL, Dang that Harvey
  • ericnliz
    Somebody has to keep you in line....HARVEY! :D
