Alde on shore power?
sugarloafer
Member Posts: 10
Our Alde doesnt seem to work when its plugged in in our driveway! Anyone have any thoughts on why not?
Have you checked your circuit breakers and the little red button on the interior outlet.
If they are all ok...Do you have the analog or digital thermostat and what setting do you have it set at.
Also possible that you blew a fuse in the Alde or tripped a breaker in your house. Out if curiosity, how long has it been on?
Under the seat where the Alde resides, check the plug. Sometimes it sneaks out of the socket.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)
Also if you have the digital controller, make sure you have the electric setting turned on. I don't have the ability to upload a photo right now, but it should be on the first menu screen toward the bottom above the propane setting.
Sheila and the Mullis Pups (Winston, Morgan, Leroy & Dakota)
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
As you have probably already deduced from the comments thus far, any one of a dozen plus things could be to blame for a non-functioning Alde...
Another thing to consider that the Alde circuitry still needs 12V power even when you are running on house current. If your converter isn't working, or if the 12V blade fuse to the Alde is blown, nothing will work. Same goes for the two hidden fuses to which jkjenn alluded--they are located on the Alde itself near where the 12V line from the converter attaches.
Also check out "Fuses for Newbies."2016 Outback 320
Thanks for all the help! Ratkity wins! 'Somehow' that plug actually did sneak out of its socket! Its 75 in there now. Thank you all!
Dem sneaky plugs! This time I can't be blamed for tripping over it and pulling it out. LOL2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)
Ratkity, No you just used to blame Harvey for that one!
Eric aka: Lone Wolf -
LOL, Dang that Harvey2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)
Somebody has to keep you in line....HARVEY!
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
