jkjenn
Member Posts: 6,417
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
I also made one from tubing that attaches to the water jugs I carry.
See, I will spend $500 on a cover but not $12 on a fill thingy
On your install of the freshwater fill fitting, was the water fill tubing and the overflow tubing, standard size to fit on this fitting? Or did you have to make modifications of the tubing to fit? Was there enough tubing to stretch out and reattach to the new fitting? Any modifications to the hole where the fitting inserts and did you seal the fitting in with a clear silicone caulk and use the stock screws from the old fitting? Thanks for any information, as the part has been ordered.
Jeff
What is that of which you speak?
Looks great on your T@B. We have this on our current travel trailer. Wonder if we could order it this way from the factory. Would prefer this over the one they normally use, just seems more durable.
The first pic is the original. The second is the finished version. My last one shows the two fillers together, a nipple connection and a hose ection I cut a piece from..
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
