Sharp edges on shower door & molding?
drpprmtdrpprmt Member Posts: 117
Has any one else found the sharp burrs on the top of the shower door and aluminum molding?
  • texasaubiefantexasaubiefan Member Posts: 62
    Not so far.  Is it the corner or the top, and what year model?   I'd imagine a dremel with a sanding bit would alleviate the problem.
    2017 T@B 320-S, Sofitel (M@bel)
    Mabel is my great grandmother that I never knew.  She took her 3 sons (ages 8-2) on an epic adventure from Alabama to Florida in the 1930's in the back of a pick up truck.  I named my female English springer spaniel after my mother.  Might as well go for broke with the brownie points in Heaven!
    TV: 2018 Ford F-150 Lariat Supercrew
    David & Jill, Houston, TX
    Back in 2015, Bert's Labrador got a cut on his back from the bottom of the door-needed stitches! Verna recommended using a fine file to smooth them down. She did throw that issue back to Pleasant Valley, now nuCamp.
  • drpprmtdrpprmt Member Posts: 117
    We have a new 2017 S model.  The top of the aluminum metal on the jam, door frame, and hinge were not finished smoothly.  They had sharp burrs.  Of course the jam is a perfect place to rest your hand when going into the shower room.  Big mistake.  Fixed jam with a file and hand with a bandage.  Hope people do a quick check so they don't find out the hard way.
    Problems like this should go back to your dealer to fix, who should take it back to nuCamp. And yes, a simple file will take care of the sharp edges. I extend my apologies from the factory.
    Mine had sharp edges on the top and I filed them down.
    Gotta love the dremel tool. So many uses!!!
    I filed mine down, too. It took about 5 minutes.
