Composting Toilet
Can't help you with if anyone has converted the one in a T@B, but here is a really good video review on them, even though it sounds like you have been researching them already:
https://youtu.be/vM71d8wMuUU
Sterling, VA0 -
From what I understand, composting toilets are a wee (pun) higher than the cassette potty. Given the curve of the T@B bath, you best not be very tall. There's also the matter of the black tank. Are you going to leave it in? Will it impede the installation of the composting potty? Most vents for potties go out the roof, but (I recently learned) the T@B's vent out the side and is tied in with the gray water tank vent. Does the composting potty need a vent? I think the composting potty generates heat, will there be enough shielding to the sides and back of the bath?
Just some thoughts. You've probably already researched all of this.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
After watching the video you could not pay me to have a composting toilet, and I didn't even watch the whole thing.
- Hash T@B Fun
2 -
Gone with the Wynns did a pretty informative video on these. I'm with Dale on this one.
The C-Head has a mod where you can divert the urine to the black water tank. It will take a lot longer to fill, obviously. Or, I've read where you can connect the black water and gray water tanks, thus doubling your gray water capacity.
The C-Head also has 2 heights, which is why i'm mostly attracted to their design.0 -
Video #2 - shows why I like it over the Nature's Head...it's cheaper too!
https://www.youtube.com/watch?v=ZjxV_079CVc
It is worth watching the entire FitRV video for the educational value alone. I had no idea all the issues a composting toilet entails. Now I know better.Dalehelman said:After watching the video you could not pay me to have a composting toilet, and I didn't even watch the whole thing.
If anything you can watch the video and start counting strikes. I bet most of us reach "Strike 3!!!" well before the video ends.
One major hurdle is the fact you don't want a composting toilet installed in a wet bath. That defeats moisture management plus the seat and ventilation are not designed for that environment.2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)1 -
You may be right TabberJohn, but just an FYI, I've researched both the C-Head and Nature's Head and both claim they are capable of going into a wetbath with minor modifications.0
What exactly would be the benefit?
- Hash T@B Fun
Someone with tremendous gag reflex not having to dump the blackwater tank. That's about it. This may not be a big deal to some people. But I personally am what is known as a "super taster" which means I have very strong sense of smell...I smell things others cannot or hours/days before others can. This is great for being an awesome cook...not so great for crazy gross smells. I have an uncontrollable gag reflex. I'm trying to circumvent that.0
Does the waste in a CP toilet just disappear?
- Hash T@B Fun
@alchemist - you'd be a great beer judge! And wine judge of course. If you indulge that is.
Mods required for a wetbath location are likely 1) replace or seal the seat cover so water/moisture cannot intrude when shower is used, plus 2) route ventilation intake from outside the wetbath (perhaps from the floor) with output to the black tank vent.2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0
The CP toilets I've seen are all pretty tall. Will that be a problem?
- Hash T@B Fun
@alchemist -- Not sure about the cost difference but have you considered the Laveo option? http://www.dry-flush.com/
Has the same seat cover issue (not designed as shower bench with extended cover), but it should completely resolve the odor issue you describe. Waste is sealed after every use and you are not exposed when emptying.
Downsides are it's not biodegradable, requires occasional battery charging, and height may be a problem (18"H x 20"D x 16"W).
However, you won't have to deal with any of the pitfalls of compost toilet operation and procedures. No venting is required either.Most reviewers like it but some are very unhappy:
http://www.homedepot.com/p/Laveo-Dry-Flush-Chemical-Free-Odorless-Portable-Lightweight-Electric-Waterless-Toilet-DF1045/2052058282015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0 -
@alchemist my boss has a Composting toilet in their lake cabin. Its a little place with no water or sewer service. They haul water from home each time they visit. Works for them.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
For me it doesn't get much easier than placing a hose in a drain and pulling a handle.
- Hash T@B Fun
OK, the original poster has given their reasons for wanting the composting toilet. It is a valid reason for them. I'll continue to remove comments that make fun of the reason they need to have a composting toilet or those that make fun of their idea.Verna, Columbus, IN
Verna thanks for keeping us on message.
- Hash T@B Fun
3 -
My parents have had an Airhead in their head (wetbath) on their boat for 10 years, and it works very well. I'm having my T@B modified at the moment to have an airhead installed. I'll go into the details such as @Ratkity mentioned in a separate post when I have photographs.
Other than the fact that it works well for my parents, the reason I'm getting it is because I will be boondocking fulltime without water and sewer hookups. Water will need to be hauled in and out (not from a hose nearby!) and will always be at a premium, and I won't want to be going through the whole process of hooking up and moving off site (I'll be working at locations for four to eight weeks at a time) every few days to find a dump station.
If you watch that FitRV video until the end, they do say that they are keeping it. Another thing to note is that they live an extreme lifestyle (which they readily admit to!) in terms of calorie consumption and fluid intake which would definitely not like 99.99% of us. I was surprised to be honest they said they would be keeping it - it doesn't seem like a fit for their lifestyle really - but to each his own!
I think one thing we have to remember is that everyone here loves their T@Bs but we all use them differently. Some go out for a day or two the occasional weekend per year and would never dream of watching television or cooking not over a campfire. Others full-time in them, and are the other end of the spectrum, and people think what we do is crazy for a variety of reasons.
What works for some would never be considered for others, but an open honest given opinion of your camping style and experience is always interesting and can be a learning experience when given with respect and interest and curiosity in others' experiences.2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
9 -
@HR_Taly, Couldn't have said it better! Different strokes for different folks, and be respectful, and mindful of the fact that their needs, or wants won't always coincide with yours.
Eric aka: Lone Wolf1 -
@HR_Taly, like I said, you've probably researched the heck out of this... those were just questions I thought would be neat to know the answers for if someone did it. I didn't even know what they were until I saw one being repaired on one of the boats seen on "Deadliest Catch". My information is limited and just would like more (a cat curiosity thing!
) Looking forward to your posts on this! 2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0 -
@Ratkity no problem at all! I just wanted to say I hadn't gone into the details because the original poster wanted to know from people who had actually install one in a T@B which I haven't (yet!) although all the measurements, specs and details are ironed out.. I guess we hijacked their post plenty already and I was feeling guilty!
Oh shoot! Sorry @alchemist, what @HR_Taly said. D'oh.. I thought I scrolled up enough to see the OP's nick. Apologies!
The C-Head composting toilet wouldn't fit height-wise with the "shelf" or whatever that is that the toilet sits on. The toilet seat would be too high. I am DIY compromised so removing that shelf/ledge the toilet sits on and putting a flat floor in the shower area so the composting toilet could sit there and be used without issue for a short person like me...is not possible. So, unfortunately I am having to stick with the black tank. Yuck. I haven't camped yet. This weekend will be my first time out. Not looking forward to dealing with aspect of it. But I guess I got no choice.
Alchemist, you do not have to use the toilet for #2. We never have and never will. We use the campground facilities, and keep a double doodie bag in the T@B bathroom "just in case." If you use the T@B toilet only for liquids and put a deodorizing product in there, dumping isn't bad at all.alchemist said:So, unfortunately I am having to stick with the black tank. Yuck. I haven't camped yet. This weekend will be my first time out. Not looking forward to dealing with aspect of it. But I guess I got no choice.
John and Henrietta, Late 2016 T@B S Max in Western New York1 -
100% fully agree with Photomom!Mark - 2016 T@b Max S (Silver/Red), 2012 F-1500
True. But I know I'll need to buck up and do it sometimes. I'm going out for 3+ months and hope to boondock or at least go out to places without many amenities. I need to just learn how to do this without freaking out so bad. But I keep running across the horror stories (exploding lines in the face at the dump, etc.
) and all I can see is me in a full-on hazmat suit and gas mask. LOL
No problems at all. But please come back here and post links to your airhead setup when you get it installed. I am very curious. Maybe one day if I get a new T@B, I'll have them modify the bathroom and not even put the toilet (or ledge) in so I can install a composting toilet. A girl can dream. Right? LOLRatkity said:Oh shoot! Sorry @alchemist, what @HR_Taly said. D'oh.. I thought I scrolled up enough to see the OP's nick. Apologies!
- 424 Service/Maintenance & Recall Notices
https://www.youtube.com/watch?v=PCuN6WW_pT0
