We have the T@B in the shop for some final problems before the warrantee runs out and the tech had some comments that I had questions about-
1. The digital menu gives you a selection for circ pump speed, 1-5. What is the normal setting for this?
2. I've read elsewhere in the Forum that the normal setting for the temperature/continuous setting is temperature. When would you use continuous?
3. He said that when the battery is disconnected, all the Alde settings revert to the default settings. Correct?
4. I've read in the Alde Manual and in the Forum that when the Alde is connected to both shore power and propane, it defaults to electrical. I've also read somewhere that if you want the Alde to provide heat and hot water quicker, you select both the electrical and propane. How is this possible?
He said that propane heats faster than electrical because the propane burner is larger than the electrical element.
5. If you run the Alde without water in the hot water tank, it is not a problem. Correct?
Thanks
0 ·
The instructions for the analog controller are a bit more specific than those for the digital controller. In "heat and hot water" mode, the electrical heaters start first and propane kicks in to supplement only if the room temperature drops by 2-4 degrees. In "hot water only" mode only the electrical heaters are activated.
Therefore, there appears to be some truth to the "heats up faster with both" theory, but just a little... I wouldn't be surprised if the propane burner was larger than the electric elements, but if you wanted to force propane use you would likely need to do that by switching off the electrical. I'm not sure the degree of difference (if any) it would make, but if I've got shore power available I'm not going to waste my propane. The electrical elements heat water plenty quickly!
Regardless of the control system you are using, you can run the Alde (for cabin heat) without water in the tank.
As far as the heating elements go keep in mind the Alde is manufactured for 220v countries.
When run on 110v I believe we only get half the watts those elements are capable of putting out.
With the analog controller you can select one element or both (3 lightning bolts). I assume selecting both heats things up faster. I'm not sure how the digital model handles this.
If you are hooked to shore power and the propane is on it does revert to electric. And when you are boondocking and forget that the thermostat is left "on electric" (and you fire up the Alde), you may hear some dripping sound. The dripping sound you hear is the pump circulating the Glycol in the system. Needless to say you will not get any heat from the Alde, until you switch the digital thermostat setting to propane.
And you cannot select propane & electric, it's either one or the other. When you are plugged into shore power the unit operates off electric and when on propane the 12V system powers up the digital thermostat and runs the unit and is heated from propane.
And yes, you can run the Alde without water in the tank. The Alde hot water tank is situated around the outside of the heating fluid tank and actually heats by conduction from the heating fluid, not directly from immersion or gas burners, so its OK to have the heating on even if you haven't got the water system filled.
With the analog unit, setting the switch to "heat and hot water" brings the hot water in the Alde tank to ~130F; setting the switch to "hot water only" brings the temp up to ~150F. It's purely a temperature control, and has nothing to do with which burners are operating or the speed at which the water in the tank is heated. While this information is in the manual, I'm a skeptic, so I tested and confirmed it myself. (http://tab-rv.vanillaforums.com/discussion/3225/alde-hot-water-test/p2).
An added feature (drawback?) of the digital controller is that it shuts the boost feature off automatically after 30 minutes.
FYI, I did my tests using both electrical cartridges, with the propane turned off. Once I pull the T@B out for the season, I might do some additional tests to compare heat up time for electrical vs. propane vs. both. I suspect the differences will be negligible, but I'll post the results when and if I have them!
Ratkity said it should be 2 what happens at the higher settings (besides the circ pump running faster)? Why do they give different settings?
thanks
This is not true with the manual control panel. I regularly use both if I want to heat up the water quickly or recover faster for multiple showers. It is true that if the water inside the Alde is above a certain temperature, it uses electric only, but if you drain it cold, propane will cycle on in (HI) mode (higher propane consumption, noise) and boosts your hot water up nicely.
If this is the case with the digital panel, that sounds like an oversight or we don't know how to configure it.
2014 T@B CS Maxx
Martha Lake, WA
If so, that's contradictory to what's stated in the manual--but I don't necessarily believe everything I read in a manual. Empirical evidence wins every time!
When I can get to my PC tonight I'll post the links.
2014 T@B CS Maxx
Martha Lake, WA
2014 T@B CS Maxx
Martha Lake, WA
I didn't see similar wording under the instructions for the digital panel.
Also I don't know if this works with just hot water only mode. I've only camped in colder weather with hookups so far.
But then I see the note further down, only one at a time. Hmm, Mike you could be right. I'd have to test with my kill a watt to see if the electric turns off when gas turns on.
2014 T@B CS Maxx
Martha Lake, WA
2022 T@B 400 BD, with 2-way refrigerator and AllPro Awning
Alde / Truma Contact
Alde E-mail: service@alde.us
Truma E-mail: service@trumacorp.com
