Our T@B came with the Lagun table. We cook and eat outdoors and only use it indoors occasionally to play backgammon or cards when the weather is inclement. Since we sleep in twin bed configuration it is mostly in the way at night.
Because we cook outdoors we use a "camp kitchen" similar in concept to the photo. It is a pain to set up and takes up lots of room in the SUV and makes annoying rattling noises.
![](https://us.v-cdn.net/5021717/uploads/editor/as/h6x4e6r65xc2.jpg)
I am thinking of installing the exterior Lagun table mount so I can use the Lagun table instead of the "camp kitchen." Questions:
1. How does the underside of the table hold up in damp, humid conditions? It looks like some kind of pressed board. Should I coat the underside with some Spar varnish?
2. What are some ideas for adding storage since I wouldn't have the shelf underneath or the rack with hooks in the back? I keep the pots and pans, cooking utensils, a small bin with cooking spray, salt & pepper, spices, etc there all the time we're camping.
I have a folding stove stand for my 2 burner Coleman propane stove and would continue to use that. And the portable grill goes on the picnic table or ground.
We occasionally use a single burner butane stove (the kind you see at buffets) and I just scored one of the electric Cuisinart tabletop ovens that RVers rave about. The latter does put out a lot of heat. I would put the wooden T@B cutting board under those to insulate the Lagun table.
Come to think of it, I could easily use the T@B cutting board on top of the stove stand and put the butane stove or Cuisinart oven on that. Then the Lagun could just be used for food prep. So back to my original questions - humidity and storage.
We could keep using ours, but for the Lagun. Need to find a way to make it useful or pitch it out. Just in the way inside. Also looking to downsize and simplify the stuff we take and have to set up.
That is the Lagun table. Elsie has the exterior mount and spacer. Neighborhood of $100, so we want to make sure it will work for us before buying it.
@Photomom What do you consider a 'good' price for the Cuisinart oven?
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
Overstock had refurbished ones for around $52 and Amazon had refurbs for around $59. I bought two and both are perfect. No idea if they still have them. If you find them on Overstock look for a coupon.
When I first heard of these some dude was asking $250 on Amazon marketplace. Last time I checked there were some at $200. Original list price was $100.
Update: Actually, I ordered two!
And we will put a silicon baking sheet under our 2 qt Cosori being vigilant to avoid any heat to get near table or also exterior Azdel wall of T@b. Saw someone put a heat deflector around crock pot to protect camper wall from heat and food. Ours stays cool enough pushed away from wall.
I used my first one at home a few times in my home kitchen a few times to check it out and work out some camping recipes. Liked it so much I ordered a second one for home use.
The other problem we ran into is that it is not possible to put the table on the exterior mount while it is put together. It is necessary to remove the vertical arm from the horizontal so that the red trim underneath the window is not damaged. While not a huge deal, it is a bit of a hassle.
The mount appeats to be about 1/2" away from the outlet. A little different than the mount on @SAM .
Goes where it's towed to by 2017 Subaru Outback
2016 Jeep Cherokee & 2017 T@B Outback
I will design just it for me!
I had a former co-worker whose son worked for an upscale lumber company who specialized in veneers. She gave me over 3 boxes filled with veneer scraps (to the business) that will last me a long time. I have domestic and exotic veneers, some of which I haven't identified the species. And then there is the Mother of Pearl strips that were left over from a 5 million dollar yacht build from South Africa that were given to me by the head woodworker on the build. Those are hidden!
I know you have trade items;) . I may be a bit slow and not produce my mods at the same rate you produce your mods!
@Verna Sounds amazing. What a treasure trove of veneer and inlay. Hmmm... maybe a little marquetry of a t@b somewhere??? I have been having tremendous fun doing mods this last two weeks (tis true!). That's what comes from doing serious lurking here in the period between ordering and receiving our t@b. Plus cabin fever
I am almost embarrassed to admit that I also upgraded the Fantastic Fan to the 7350, added a MaxxAir cover, added a cut out switch to the Jensen and mounted an "action packer" type box to the outback platform. Oh yeah- I also modified the ends of my XL visor (where the pole pockets) by stitching a webbing loop on so I can stretch it to the handles ( ala @Nomad )
