Ok, so I'm new to rving & thought that I had successfully dewinterized my T@b. It's a Max S. After I flushed the lines thru the water tank & changed over to camping mode, I hooked the water up (with a regulator) & as soon as I turned the water on it
started running out of the rear of the camper thru a clear line behind the left rear tire. What have I done wrong? Do I have the valves open/closed correctly? Any help or suggestions will be greatly appreciated.
As ericnliz said, as long as it stops I wouldn't worry about it. If it doesn't stop (and you are sure your pressure regulator is working properly) I would cast suspicion on that valve.
2022 Ford F350 Tremor | 2022 Cirrus 620
Oh, and take a flashlight with you, remove the cap & shine inside, it's MUCH easier to see the level that way. Take a Sharpie pen, and mark the levels on the side too while you're there!
Correction: Looks like the cold water drain valve is closed in the lower pic. Look for the yellow ALDE valve.
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
The drain also functions as a pressure relief for the upstream side of the Alde. If you are sure it is closed and it's still leaking, the valve is stuck open. You can try to unstick it by opening and closing it a few times. If that doesn't work it is probably defective.
@RollingLagrima, Thanks for the picture to clarify!
