Front window rock protection
1 pc of corrugated black plastic 24"x36" sku# 074507996159 $9.22
1 pc plastic sunlite 8mm U channel 8' sku#
763552401397 $4.47
1 roll of Scotch or 3M red back double sided trim tape. About $5.00
- Hash T@B Fun
Dale, this is a very clever solution. I like how you are thinking. I wonder if bubble wrap or some padding on the inside of the plastic, facing the glass would add a little cushion?
3 -
Dale,
Is it pretty tight? Can it slip out? Need to put some kind of an end cap to hold it in place? I see a factory option here!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
Nice job @Dalehelman! The Mod king strikes again!
Eric aka: Lone Wolf0 -
Very nice, well done.
Sterling, VA0 -
I just did this. So l can not report on the long term . It is very secure. If additional refinements are needed I will pass them along. I expect it to stay in place during speeds in excess of 75 mph.
- Hash T@B Fun
jkjenn said:Dale, this is a very clever solution. I like how you are thinking. I wonder if bubble wrap or some padding on the inside of the plastic, facing the glass would add a little cushion?
At this time I don't think it would be necessary. The corrugated material should disperse the impact force sufficiently.- Hash T@B Fun
@Dalehelman, WHAT? Are 'ya goin' downhill, or drag racin' T@Bs?
Now, if you could figure out how to throw the rocks BACK at 'em.......
Nice! Looks like black or white is the choice since colors only come in 10 packs. :(
May work for AC vent cover as well (channel at front/top/bottom of vent; Velcro or dual-lock at rear).2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)1 -
I bet you could find some Krylon Plastic rattle can paint to color match. Even make a reversible color option.
I am going to 777 spray adhesive the panel and smooth some flannel on the back of mine to avoid rubbing.2015 T@B Max CS-S Silver and Black
Goes where it's towed to by 2017 Subaru Outback3 -
May work for AC vent cover as well (channel at front/top/bottom of vent; Velcro or dual-lock at rear).Check with any lawn sign company. Coroplast comes in many colours.
James & Jacquie Almonte, Ontario
2016 Jeep Cherokee & 2017 T@B Outback0 -
To avoid scratching the window while driving and aggetating the surface, maybe cut the black cover slightly wider than needed causing a gentle bend when installing.3
It has a slight curve and does not contact the window other than at the very top and bottom. If done properly it does require some degree of force to install and remove. I don't expect any movement why'll underway.
- Hash T@B Fun
Nice. We went a different way - full glass coverage on our T@B insurance policy.John and Henrietta, Late 2016 T@B S Max in Western New York2
Thank you for sharing this! Definitely going to add this to my t@b.Light a campfire and everyone's a storyteller. ~John Geddes
2017 t@b CS, silver with green trim.
TV: 2017 Honda Ridgeline.0 -
I have that, too, but not exactly convenient when in the middle of nowhere!Photomom said:Nice. We went a different way - full glass coverage on our T@B insurance policy.
I am thinking for those of us with the non-opening window, we might be able to fit something with elastic that snugs around the window.
Duct tape and contractor bags! Don't leave home without 'em!John and Henrietta, Late 2016 T@B S Max in Western New York0 -
Yeah, I'd rather not have it break if it can be avoided. Nothing spoils a cute trailer's appeal like a contractor bag and duct tape. Find a fix in transit seems like it could be a more simple solution.Photomom said:jkjenn said:
One question though are the silver edges not the same material as the window therefore should also be protected?0
Possible yes.Mega said:One question though are the silver edges not the same material as the window therefore should also be protected?- Hash T@B Fun
Nice job!
John2007 T@B
Rockford, IL
I love to come up with new ideas. It's up to you all to help me refine them, and if you like them make them work for you.
- Hash T@B Fun
4 -
You know that stiff pink insulation? I used titebond II glue to make edges for it. Then used the titebond II glue to put on fabric of my choosing to cover it. That was for covering the solar panel on my reverse LG TD - perxactly in the position of that front window!!
Now I had that held on with straps and buckles and you can't do that.... BUT, those industrial plastic to plastic outdoor Command strips were not available. It's a way to match your camper's color and style and you can take it off when you park. The key would be to have the edges pushed down tight.
It was just an idea and you'd have those strips visible when you took the cover off. Would there be an Earth magnet option where you could color the magnetic strips? Could you put strap holders at the top and bottom of the window (where would they come out inside? and they'd have to be reinforced inside). Strap holders would be much more inconspicuous and not distract from the T@B look. BTW, strap ends need to be tied down - tip for those who've never traveled with tie-downs.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1 -
I dunno @jkjenn, I wonder if our front windows might be less susceptible to damage because they're (tempered?) glass.
I'm not looking forward to hooking a trailer to the back of the Tab for all its accessories!
Maybe better mud flaps would suffice?
Just a thought. (I do like your solutions @Dalehelman
) Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
Remind me - what is the difference between the current windows that open and the permanently closed windows? Is there a glass difference?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Yes, the earlier window, which doesn't open, is tinted, single-pane, and heavy glass, and I'm guessing that it's tempered, haven't checked. It's also curved to match the curve of the front of the Tab.SAM said:Remind me - what is the difference between the current windows that open and the permanently closed windows? Is there a glass difference?
Thanks Chan. So, the current opening windows are double pane Lexan?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@ChanW I recall someone saying they got hit by a rock during travel had their non-opening window and it was tempered, but did not have the 'plastic' sandwich that a front window of a vehicle has. It's more like the side windows of a vehicle. The people who had their window broken said they were picking tiny glass pieces forever.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
@Ratkity Happycamperswives have a video of thier front window shattering into many tiny pieces everywhere. Now they are lexan, and I put clear packing tape over my 3-4" crack from a rock. I have purchased a replacement from NuCamp but may wait till the season is done before replacing it.2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
There is clear repair tape that Gorilla Tape makes that may be a little weatherproof, but leave the packing tape if it's working. I understand just waiting to replace the window until the season is over if it's not anything more than a cosmetic issue and doesn't leak.Homebodyatheart said:@Ratkity Happycamperswives have a video of thier front window shattering into many tiny pieces everywhere. Now they are lexan, and I put clear packing tape over my 3-4" crack from a rock. I have purchased a replacement from NuCamp but may wait till the season is done before replacing it.
Good luck in the replacement!
- 30 "FOR SALE" - New/Used Trailers
