Water Tank Filling
I use a 5 gallon collapsible water jug to fill my water tank when a hose is not available. The cover on the T@B snaps out to make a small funnel. I remove the nozzle cap from the collapsible jug and pour away. It takes a few minutes to pour in the water and you loose some from spilling and the fact that the filler cap on the T@B is not completely leak proof. Unless my tank is absolutely empty I find two jugs fills it up. It is a simple system that stores well, has no moveable or looseable parts. As long as I can comfortable lift the jug this will be my system.2016 T@B M@X S grey/red 16 Foot Airstream, towed by 2014 Jeep Grand Cherokee V6 4x4, Central Connecticut
Thanks, but too heavy for me to lift and hold. I'll stick with putting a four or five gallon jug on the front diamonds plate tub and using a funnel and clear tubing to fill my tank. Easier for we weaklings
Even easier is a filling a simple bike bottle ( or any bottle, really) and filling it up a several times from my collapsible container and using a funnel on the filler cap into the T@b. I'm camping, not in a hurry, and I'm not hoisting a 30 pound water keg for anyone.
Towed by 2014 Touareg TDi1 -
Has anyone tried this to fill the fresh water tank from another container? I figure for $6.99 from (as my brother calls it "Horrible Freight") you can't go too wrong in trying.
(I wouldn't typically drink out of my water tank but use it for showers and dishwashing - not sure if this might leave a taste to potable water).
https://www.harborfreight.com/multi-use-transfer-pump-66418.html
Multi Use Transfer Pump
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
HR, I tried it. My arm hurt after a gallon. Let me know how you fare!!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)2
This is the basic idea, although I have changed to 4 and 5 gallon blue jugs and added a funnel instead of the on/off fixture (the jugs have an on/off slide). Gravity is your friend, and a great help to your muscles
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”4 -
Verna, we tried this system and if it wasn't for the flimsy regular tub top, we would be in business. I agree, gravity works wonders.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I may have to try that!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
Could you just put the container on the kitchen counter (if you have a front kitchen) and run the tubing out the window?2017 Max S - Silver/Red - T@briolet - 2016 Jeep Cherokee - Fredericksburg, TX2
Oh, good idea! We have a CS with a front counter. Worth a try!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
I don't know how many times @Sandiegogal and I have handed each other stuff through the window....never thought about setting something on the counter so you could use it outside.2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.2
We home winemakers have a solution. And it's food safe. http://www.northernbrewer.com/super-transfer-pump-with-pre-filterJohn and Henrietta, Late 2016 T@B S Max in Western New York0
- 421 Service/Maintenance & Recall Notices
