We have a 2007 T@B which we tow with a manual Subaru Forester.  Well we will do when we ever get out the driveway!  We are new to the whole towing game.
We are scheduled to go on a trial run to northern Wisconsin on Wednesday so we get clever and buy a spare tire carrier we can attach to the tongue so we have more space in the T@B.  Seems like such a great idea.
We tried to check the tongue weight this evening with the tire attached to the tongue.  We put the household scales under the little wheel at the front of the vehicle.  It weighed 320lbs and the Subaru has a max weight on the tongue of 200lbs.  Can the new location for the tire make such a huge difference?  We have towed it 2 or 3 times locally with no problem but now it is loaded up with food, water, LP gas and the tire!!
HELP!!  Are we checking the tongue weight accurately?  Will the new placement of the tire make such a huge difference?  What do you, the T@B community, recommend?
                0 ·
After relocating the spare on my 2015-S, my tongue weighed in at 209 lbs. That's with a full propane tank, a group 27 battery, water in the Alde tank, and a full complement of gear stashed under the rear seat. I did not have food in the fridge, or water in fresh water tank (which appears pretty well balanced over the axle).
Where you take the measurement can also make a difference, I weighed mine by setting a short 6x6 post on a scale, and setting the hitch coupler on the block.
Unfortunately, I did not weigh the tongue before relocating the spare, so I can't comment specifically on the impact of shifting that load to the front.
Anyway we have decided to remove the spare and go back to the status quo we had as that seemed to work fine. But I would like to accurately measure the tongue weight if I can.
You don't say which model T@B you have. Watching here and from my own experience the location of the kitchen has a big influence. Those with the kitchen in the rear appear to have fewer challenges with hitch weight. The fridge, stove, all the pots and pans, and food move to aft the axle to help balance the battery and LP in the front.
Also, to get an accurate tongue weight you should place the scale on a block and weigh the tongue level with how it will be towed at the coupler. Measuring at the jack would cause a lot of leverage that would throw the result way off.
Sterling, VA
The Subaru has a towing capacity of 2400 lbs when towing a trailer with brake sand a tongue weight max of 200 lbs. Does my camper have brakes? I feel very foolish even having to ask such a question!!
We will weigh the tongue using the advice from here in the morning and see if it is back within the recommended limits.
Not following this rule can affect gas mileage/wear n tear, and handling.
You can 'adjust' the tongue weight by counterbalancing any excess weight that is forward of the trailer axle, by increasing stowed weight behind the axle.
If your tongue weight limit is 200 lbs, then that will dictate a trailer weight limit of @ 2000 lbs, pretty hard to meet when the Tab weighs in at 1650 dry weight (ie, no battery or propane, water, food or luggage)
You should also check the max load limit of your Forester.
2019 Ford F-150 3.5L Ecoboost with Long Bed
9-15% is a general rule for tongue weight.
The etrailer site shows these measuring methods: https://www.etrailer.com/faq-how-to-determine-trailer-tongue-weight.aspx
Too little tongue weight causes trailer sway.
Too much tongue weight affects TV handling.
Now we could take the tire and mount off and save 50 pounds. I'd rather not though. I am driving a Ram 1500 with a class 4 hitch and the chart says I have a max trailer weight of 8150. It also says something about the reccomended tongue weight for a conventional hitch is 10 percent of the gross trailer weight.
My question on this is does the TV size affect the tongue weight number at all. I don't mean 1100 pounds, which is the max weight for a class 4 hitch. I'd be at about 350. Is that too much do you think? I understand the basic concepts of tongue weight and don't want the long timers to groan at yet another question about it.
Just that I'd be looking at 350....
Am am I thinking this right, and could the tire stay by putting some heavy items inside toward the back? The the truck size help in this?
(Is there a way to delete my questions in the discussion about adding a bike rack by another member, thus cleaning up the area. )
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
The Maximum Trailer Weight Rating of 8150# is your trucks tow capacity which far exceeds the TaB weight, so you are more than good there. And your hitch tongue weight capacity is more than enough at 1100#.
So, in your case, the limiting factor is the TaB fully loaded weight. You want at least 10% up to 15% of the TaB weight to prevent sway. So, if your loaded TaB weight is 2200# then you need 220-330 # tongue weight to safely tow the loaded TaB. And you are correct, once you determine your loaded TaB weight and desirable range of tongue weight, you can adjust how you load the TaB to increase or reduce the tongue weight.
Which post do you want deleted?
Sold 2023 Tab 400
Sold 2018 T@B 320S
T@bbey Road
Appleton, WI
