Hi All,
I pulled my tech specs from my VIN number and I am hoping I read this correctly.  Could someone let me know if I do have the 2.0L engine that will tow 3500#.  I purchased a new T@B Max which I get in March :-)   The confusion is for me is under
Maximum Trailering Capacity shows both
3500, 2000 lbs... 2000.0 min 3500.0 max.  Does that mean
3500#?   And does
Displacement 2.0L mean I have the larger engine?  I just want to make sure I have enough towing to pull my new T@B!!
Thanks in advance! Marilyn
Tech Specs
								 		Drivetrain
		 			Front Wheel Drive
	 		Base Curb Weight 	 			 			3592 			 				 lbs 				 			 				 3502.0 min 3592.0 max
 	 		Fuel Economy Est-Combined
		 			25, 26 			 				 MPG 				 			 				 25.0 min 26.0 max
	 		EPA Fuel Economy Est - City
		 			22, 23 			 				 MPG 				 			 				 22.0 min 23.0 max
	 		EPA Fuel Economy Est - Hwy
		 			30, 32 			 				 MPG 				 			 				 30.0 min 32.0 max
	 		Dead Weight Hitch - Max Trailer Wt. 	 			 			3500, 2000 			 				 lbs 				 			 				 2000.0 min 3500.0 max
 	 		Dead Weight Hitch - Max Tongue Wt.
		 			350, 200 			 				 lbs 				 			 				 200.0 min 350.0 max
	 		Wt Distributing Hitch - Max Trailer Wt.
	 		Wt Distributing Hitch - Max Tongue Wt.
	 		Maximum Trailering Capacity 	 			 			3500, 2000 			 				 lbs 				 			 				 2000.0 min 3500.0 max
Engine Order Code 	 			 			999 			 				  			 			 				 999.0 min 999.0 max
 	 		Engine Type
		 			Intercooled Turbo Regular Unleaded I-4
	 		Fuel System
		 			Gasoline Direct Injection
	 		SAE Net Horsepower @ RPM
		 			231 @ 5500
 		SAE Net Torque @ RPM
		 			270 @ 3000
You might look on your driver's door jamb for the specifics for your vehicle.
It might be more specific to your vehicle.
Just a thought.
Previous 2017 T@B S owner... c'est l@ vie
But still passionate about the brand!
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
My '13 Escape came with a tow package, but I think all it includes is the hitch and an electronic sway control. It did not include a transmission cooler that I know of. You definitely need the brake controller for the electric brakes and the 7-pin plug.
In either case, the 2.0 ecoboost has sufficient power -- 240 hp and 270 lb-ft torque. Plenty for towing a T@B.
The only issue is the sway control. if you have aftermarket hitch, your vehicle is limited to 2,000 pounds, sufficient to pull a T@B without any issues. From a power perspective you are fine (assuming that the aftermarket hitch is rated for capacity).
I really appreciate all of your help, thanks guys!
2017 T@b 320 S
2017 Kia Sorento SXL AWD
Please Google your New York State laws regarding brakes on trailers. Please do not rely on your salesman who makes a commission on each sales nor whoever else told you not to connect them. Your T@B will weigh in excess of 2,000 lbs when loaded with battery, propane, food, clothing, etc.
If your Escape model includes the 3500 lb tow package you could certainly pick up the T@B without a brake controller. You'll need a 7-way RV blade to 4-way wiring adapter for the lights to work.
Just remember there's 2000 lbs of rolling weight bearing down on your vehicle in a stop. The Ford will handle it fine, but not in the same fashion as with a brake controller.
Eventually you'll be camping in the mountains or traveling scenic byways with long descents. Or just need to slam the brakes on in the rain. That's when you'll appreciate the brake controller. Better safe than sorry.
BTW: When you do add the brake controller remember to test it as a trip checklist item.
NY DMV: "Trailers weighing over 1,000 pounds unladen, and trailers having a maximum gross weight in excess of 3000 pounds, must be equipped with brakes."
Same deal... started to rain and the oil/rain mix makes the road slick. There he was, a little red truck barreling up behind me and cutting in and out of heavy traffic on I-10 (Katy Fwy) outside of Houston. See "Construction" caution sign ahead. Yup... he did it. He realized he was going 60 mph and everyone else was slowing down to the 30's. He cut right between me and a beautiful old Ford truck (the big solid ones from the 70s). I believe the popup's brakes slowed me down faster than my truck brakes. I totally believe in brake controllers and for larger trailers, sway and weight distribution hitches.
And now, the end of the story.....
I swerved into probably the only grass median on that hwy and slid up the wet grass past the accident. The poor Ford truck had its bed smushed in a little bit and lost its 50 lb bumper (driver was ok, but just bought the truck that day). I know it was 50 lb bumper because I had to pull it out of the road so cars could get by.
The little red Mazda truck that caused the accident was totaled and front end totally mushed in - guy had a knee injury and bumps and bruises (days before air bags). Other than the red Mazda driver trying to intimidate me with a false lawyer letter, all ended well. My insurance company caught the fraudulent letter and the fact he had no insurance at all. I even had my $500 deductible paid back. After seeing how the big Ford vs the small Mazda faired in the crash, I decided to get an adequate TV - my beloved 1994 Chevy V8 350 - silver with a blue belly (Dallas Cowboys colors). Grill guard included. I had that truck 13 yrs - still sorta regret selling it. Ah, memories... (fin)
