I have not seen much posted on best practices for using the wetbath, particularly in terms of the sewer tanks. Has anyone used theirs enough to establish best practices? I understand many try to use campground facilities when possible, but these tanks are small and would love feedback on:
1) Any problems people have had
2) How do you know how full your tanks are?
3) Cleaning and deodorizing your tanks
4) Anything that makes usage different than other RVs.
 I have purchased a
sewer hose,
a Flush King elbow,
Happy Campers Organic RV Holding Tank Treatment,
disposable gloves and
the risers for the sewer hose. I still need to pick up a hose for the Flush King.
For example, how can you tell when you need to empty your tank? Do you make educated guesses and shine a light down the toilet with the gate open to verify? Do you have a system or process worked out for dumping the tanks? Are there things about dumping or using the wetbath set up on the T@b that would differ from other RVs?
I guess we'll figure this out together.
Keep in touch.
I did purchase a hose carrier and attached it to the side of the trailer. We put the sewer hose in the carrier. I store the connectors in a water proof bag and keep the bag inside the housing on the trailer. What do you do with your sewer hose?
While the sewer hose is too long (15') to fit entirely in the vertical PVC pipe, the hose is stiff enough to fit across the top of the front accessory box and angle downwards. There is an anchor bar on the side of the accessory box which I affixed the rest of the hose to by putting together two "ball" bungee cords. I can't believe how secure this is, and I am very pleased with this solution for storing my sewer hose. The accessory cover can be closed easily and latched. I did have to take off one of the bayonette fittings on the hose. However, this doesn't cause me heartburn because I need to save on space!!!! =P~
Both gray and black water tanks should be cleaned regularly. Here is a great little article from Good Sam about keeping a black water tank clean.
Sterling, VA
Beth, that is a great set up. I noticed the PVC pipe when I peaked into the unlocked T@bs at LG HQ on Sunday during my exploration of eastern OH on my way back to Pittsburgh. I would also like to install a floor into the accessory box so I can store set-up type of gear inside. I think poultry flooring might be a good option for that.
We will put another shorter carrier on the left side soon. We store the connectors in a separate storage bag.
http://www.amazon.com/Valterra-T1020-5VP-Water-Drain-Adapter/dp/B000HDIBDI
Stan - No, I've no intentions of using it for the black water tank. The 2014 T@B S M@zxx has both a black water drain and a gray water drain. I want to use it to hook up my gray water tank so I don't have to empty it while I'm de-winterizing my T@B. I'm going to use the disposable "poo powder" bags if I use the toilet. I'm still new at all this, and using the dump station is a little further away down my learning curve. Right now, I'm just trying to navigate the Alde system, de-winterizing, and making sure the refrigerator and stove work!!!
I think I found the right components. I'm going to try all this out next weekend. Thanks for your guidance.
[-O<
