I was surprised when I arrived home to find the battery was significantly drained. I'm pretty sure this must be user error. My seven-pin tests as working fine. I had the battery switch set to on. The fridge was set to battery. Thoughts? What did I do wrong? The only thing I can think of is to run a check on the fuses.
Red and White, 2017 Max S being towed by a 2014 Honda Ridgeline. Hello Mountains!
0 ·
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
One exception to to this is a Ford tow package that uses a second alternator on the engine exclusively for recharging the trailer battery and whose output is controlled by the trailer batteries. Expensive tho. seems like an electronic equivalent might be possible but I haven't found it.
If you are getting power at the 12V charging pin on the tow vehicle plug, and your battery is connected, and your fridge is cold, than a blown fuse is unlikely to be the source of the problem.
It's possible--but also unlikely--that the 12V charging wire in the trailer pigtail is broken or disconnected. That would force the fridge to run exclusively off the the T@B battery.
As others have noted, this is common issue. While your alternator seems sufficient, I've noted that alternator ratings usually reflect a relatively high engine RPM. At more typical cruising speeds, the output is considerably lower, not to mention that a chunk of that power is needed to run the vehicle systems. I wonder if that is at the root of so many T/V's being unable to keep up with the fridge.
2022 Ford F350 Tremor | 2022 Cirrus 620
I have a group 27 battery in good condition, and tow with a stock Nissan Frontier with a charge/aux line to the 7-pin plug. When we broke camp the battery was showing >12.4V under light load (fridge running on propane and the usual phantom drain suspects). On departure, I switched the fridge to DC, then drove the ~7.5 hours home at highway speeds with the engine at ~2000RPM. If we stopped for longer than it took to get gas, we turned the fridge off.
I arrived home with the battery showing <12.5V (no load). While certainly not depleted, it was not fully charged as it would otherwise be after such a long trip.
So, while I might opt to use the fridge on DC for a long trip in hot weather, I think I would shut it down within a couple hours of arriving at a campsite without hookups. YMMV depending upon your T/V, driving style, and battery condition!
I have a theory that those of us who prefer to drive at freeway speed whenever possible, will always have trouble keeping the propane lit during travel.
In California where I live, that would be 55 if I'm driving the speed limit but I never do mostly 65 in CA and 70+ in other states where it's legal. I didn't have any trouble with it staying lit while driving up to the local mountains. But I couldn't ever get over 60mph on that trip. Didn't have any trouble driving the freeway from San Diego to San Clemente (45 minutes), but there was traffic on the 5 and rarely got it to 65 mph that day. At 70 mph, I can't keep it lit for any significant time. Add huge crosswinds and it's impossible to keep it lit at all. But on a trip like that you only stop every few hours, so it's impossible to know how soon it's actually going out. I have plenty of battery (200AH), so even though my 2016 Sorento can't keep up with the charge, I usually have plenty of battery when I get to camp.
However, my biggest concern is how hot it got running it on 12v across Arizona when the temps were triple digits and that was in early June. We were on our way home and didn't have any raw meat and not much to lose, but the temps got close to 60 degrees in that fridge.
2016 Orange MaxQ
Henry's Fork River, Eastern Idaho
That said, your battery doesn't charge that much while you drive. You can even lose battery charge if you run the 3-way frig on 12V (if you have that frig).
Good luck tracking down your power gremlin!
2016 Orange MaxQ
2016 Orange MaxQ
The second post from the right connects (among other things) the charge wire from the pigtail to the positive wire from the battery. The first post from the right does the same for the negative wires. The rest of the spaghetti is irrelevant in this case.
Figure out which wire is which, and check both lines for continuity between the trailer plug and the junction box, and between the junction box and the battery. If both are intact and properly connected, your battery should be charging while you drive.
Good luck!
2016 Orange MaxQ
2016 Orange MaxQ
Alan & Patty
Southern Az
2016 Orange MaxQ
