Thanks
qhumberd
Moderator
A/C vent cover custom fabricated
I fabrcated this custom A/C door so rain, wash water, cool drafts will not get in my A/C cabinet. It looks and works great! I ended up building 5 of them with the left over diamond plate. I have 1 left if anyone wants to buy one. Cost is 200 + shipping. Comes with all hardware to install.  Easy install and modification. I may make more if there is enough interest. All hardware is stainless so no rusting! Does not fit on some clam shell models. Questions, you can email john@coolparrot.com
  • Michigan_Mike
    Nice!  Spring loaded latch, side supports and no worries about water entry as it's sealed around the edges too.  I love these kinds of custom projects and you did a great job!
  • hymie
    hymie Member Posts: 150
    Just finished our version of this great mod. I added foam blocks between the louvers to help keep the hot and cold air separate.
    James & Jacquie     Almonte, Ontario
    2016 Jeep Cherokee & 2017 T@B Outback
  • Coolparrot
    Coolparrot Member Posts: 18
    Very cool! Nice job/design.
  • Tabaz
    Tabaz Member Posts: 2,420
    You guys really outdid yourselves with these two designs. Very impressive. However, both seem to render the stock white grill superfoulous. Any particular reason for leaving it in place?
  • Ratkity
    Ratkity Member Posts: 3,770
    To keep the bug screen attached? @Tabaz?
    Hey Mike and Verna, any chance nuCamp would add this mod as an upgrade or sell it in their upcoming online store?
  • ericnliz
    ericnliz Member Posts: 4,437
    Nice job guys!!!! @Coolparrot & @hymie!!!! @hymie, Good thinkin' on the louvers & foam blocks. How much does it help your A/C efficiency?
  • Michigan_Mike
    I'm guessing that this is more labor intensive than nuCamp would want to take on unless they could have them made up at a competitive price.  They do have as you know, the vinyl cover that you can buy and that basically snaps on across the face of the grill and costs around $20.
  • ericnliz
    @Michigan_Mike, I agree with the cover issue, but a better ventilating system needs to be incorporated to "exhaust" the hot air from the inside. The auxillary fan was a good idea, but not efficient enough to exhaust enough of the accumulation inside the A/c compartment. IMHO. After looking at @Dalehelman's mod for this issue, and the one that @hymie just did, the louvers indeed address the issue better. Just a thought.
  • Michigan_Mike
    The small black vent at the top of the trailer just doesn't seem to allow much air flow for the AC unit.  @hymie, how much of a difference have you found in your over all efficiency of the AC unit with the divider above?  I believe that therein lies the problem/solution for units with the grill and will bring this up at the rally when I speak to the nuCamp R&D reps.  I have discussed this with Pop-T@B and we both concur that some time of (even an add-on) cowling could be designed that fits over the grill, provides separation in the incoming/outgoing flow of air and would improve the efficiency and amount of cooling that takes place with these units.  Shawn did improve his efficiency using his homemade cowling and in conjunction to attaching rare earth magnets to keep it in place.
    Some very creative/innovative work above and should help on all fronts!  2thumbsgif
    Thanks Mike.  We have that cover.
  • hymie
    @Tabaz the stock grill does very little except direct the air down.
    @Ratkity the bug screen is held on using metal duct tape which does not hold. Replaced with red tyvec tape which sticks like crazy.
    @Michigan_Mike lol. We live in Canada. Haven't had to use ac yet. Stands to reason that separating the air flow can only work better! I think that @Dalehelman identified this correctly as an issue that needed a solution.
    Thanks to all for the great ideas!
    PS Working on a fix for the pahaque tent roof not shedding water well. Looks good so far. I will post when complete. Stay tuned!
    Cheers from site 61 Bonnecher provincial park!
  • Michigan_Mike
    The only thing you guys need up there is a full-standby case of mosquito spray handy!   =)
    Hymie, we used collapsible tent poles and some PVC.  Works like a charm.
  • hymie
    @Michigan_Mike. Had occasion to test the ac in 90 degree weather (full sun). There is a strong blast of hot air from the centre exhaust that dissapates several feet from the grill. Very little spill over to the cold intake. Only design change that I will be considering is to extend the fins further. Overall I am delighted with how well this works.
    Ps the mosquitoes say hi! Drank their fill this last couple of days at Bonnechere provincial park.
  • richardlacroix
    richardlacroix Member Posts: 16
    Michigan Mike, could you please post the URL of the web site with the $20 canvas cover for the A/C grill; Thanks
    Richard Lacroix
    Ellen & Richard Lacroix | 2015 Jeep Cherokee Latitude V6 | T@B Max S 2017
  • HerFineMess
    HerFineMess Member Posts: 23
    @Michigan_Mike I know this is probably an expired post, but do you have the information on the 20 dollar cover for the A/C grill? I want to get a cover, but the beautiful diamond plated ones are not in my budget.
    --Meg
    Mostly A Solo RV Chick
    T@B Outback
    Jeep Grand Cherokee
    Here is the picture ofthe vinyl cover that you can purchase (via your dealer now).  Simple and effective.  It comes with srlf tapping snaps.
  • Ninabean
    Ninabean Member Posts: 68
    I have the vinyl cover.  When are we suppose to put it on.  ???? Just for storage?
    2019 T@b 400 “Hazel”   Towed with a 2013 Ford F-150 STX  4X4 SuperCab 5.0L
    table mod
    You can put it on for storage, but be sure to remove it when towing.  We use ours when it is cold and windy.
  • Michigan_Mike
    I never had any issues with it traveling.  I left mine on full time and drove out west with it in place as it’s pretty taught snapped in place.
    Wow @Michigan_Mike.  Never thought it could withstand that!
  • Michigan_Mike
    The cover on my 320 was (let’s say) spot on.  When it snapped into place it was tight.  The only thing I had to do was to make sure I took it off when I ran the AC.  😄
  • Ninabean
    Thank you all for your responses. Thank
    table mod
  • DenisP
    DenisP Member Posts: 542
    Another take on an A/C cover for a 400. Made from plexiglass with Dzus fasteners. The graphics are a result of playing with DW’s scanncut  we are using the cover to put National park stickers
    2013 Tundra TRD 5.7L
    Massachusetts
  • Marceline
    Marceline Member Posts: 1,745
    It looks great. How did you attach the springs? It seems like there's not much for them to hold onto. Or did you make some kind of backing behind the grate?
  • DenisP
    edited July 2019
    I used Dzus fasteners which have been used in aviation and car racing for years. A quarter turn securely holds the panel.  I purchased them from Chirco Performance & Restoration.
    Dzus Spring Retainer W/ Tab Dune Buggy Sand Rail Sold Each | 821104
    Dzus Fastener, Self Ejecting Stud Dune Buggy Sand Rail Sold Each | 821100
      I used the type that could be pop riveted-on The male part on the plexiglass and the female on the inside of the A/C. I had to take off the cover for the mod which was relatively easy. At the same time I added window screen to the inside of the expanded steel A/C cover to keep bugs and small critters out.
    Here is the latest picture with our added National Parks stickers from our current trip. 10 US and 4 Canadian so far.
    Massachusetts
