Renogy Sale
There are some great deals on open box solar suitcases with and without controller now through 9/5.  Check it out.  Including their newest Eclipse models.
    foxdenfoxden Member Posts: 148
    Thanks @SAM If I get the 200 Watt Eclipse and use the standard T@B battery, would it provide enough power for a fan or two at night and maybe a few lights?  I would expect sunny days for the most part.  If I can take my trailer down to the Texas coast, I probably wouldn't have any power available.  But I am not sure I am ready to get the somewhat expensive larger batteries before I go.  Any thoughts?
    2017 Max S - Silver/Red - T@briolet -  2016 Jeep Cherokee - Fredericksburg, TX
    @foxden, there really isn't a "standard" T@B battery because the dealer puts what they have on hand into the battery box. The only standard is that it be a group 24 deep cycle or mixed deep cycle. I've seen the amp hours as low as 65 (my sister's) or as high as 85 ah (mine).
    200W is a nice size solar set up. Keep in mind you won't always have sunny days and usually only have a max of 4.5 hours of useable daylight.
    You'll need a meter for the battery. Just go and get a regular multimeter to measure 12V. Not just use the SeeLevel controls or plug-in to the 12V sockets. Those are hit and miss if you are worried about draining your battery or going long-term without shore power.
    This would be a great training time to see how much power you use a day and how much your solar panel replenishes what you use.
    Remember 12.8V is a 100% charged battery and 12.1-12.2V is 50% drained battery (without loads). When charging, it's good to see 13.5-13.7V on your meter. It means the solar is keeping up with use. You'll see the value drop to about 12.6V as the daylight drops. That's a "rule of thumb". Good luck!
    Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,506
    @foxden,  as Ratkitty reports, you need to know the amperage (capacity) of your battery.  Commonly the dealers only install a 75 amp battery of which you can only use 35 watts before you need to recharge with solar.  Off hand I don't remember the draw on the stock fantastic fan and it varies by speed.  200 watts with appropriate sun will charge you up faster, but your issue is what happens if you run your fans all night and wake up to a couple days of clouds and rain.  That is where the advantage of higher capacity comes in.
    rkj__rkj__ Member Posts: 641
    edited August 2017
    According to my search, the Fantastic Fan draws 1.25, 1.8, & 2.4 amps, depending on speed.
    http://tab-rv.vanillaforums.com/discussion/3422/trailer-power-demand-information
    So, assuming the low speed setting, running for 9h, you are drawing 11.25 Amp hours from your available 35 Amp hours.  When you add other draws, like lights, you end up near making it two nights on a charge.  With a 200W solar setup, you will be able to get some charge on cloudy days, and it will have no trouble topping up your battery with a few hours of good sun.  But, if you have a few really cloudy days in a row, or have some shading, solar solutions can struggle.
    Thanks for the info!  I have an Interstate RV/Marine battery SRM-24 that, according to my googling, has 82 ah.  If things get really tough and am down there for awhile, I can probably change out the battery.  I eventually intend to that at some point any way.
    pthomas745pthomas745 Moderator Posts: 3,670
    Print a copy of Jenn's spreadsheet and tape it to a wall somewhere in the trailer.  Every time you switch on a light or run your fan, etc,  refer to the chart for a second and think about how much power you are using, and then think about your battery state of charge.    After a few days of that sort of thinking, you will start to get a feel for power use.  You would have to work pretty hard turning things on all day to run down 35 amps!  The only time I get really concerned with power use is when the sun isn't out.
    Thanks again.  I feel like solar will be really beneficial for the short term but long term will open up a whole new world of camping!! :):)
    jgram2jgram2 Member Posts: 1,522
    edited August 2017
    The one I was referring to is the one rkj posted earlier in the thread.  Here is the link to that thread:
    Those spreadsheets all go hat in hand with Jk Jenn's blog where she discusses battery management and her solar power setup.  I'd fooled around with solar panels for a couple of years in a very small way, and when I bought my Tab I was confused about how far a 100 watt panel and a group 24 battery would take me.  Jenn's clear hints and instructions and the spreadsheets saved me from my confusing "guesswork"  and so many comical internet "discussions."  It did take some "practical application" like everything in the Tab, but it is working quite well for me, and I would assume many other owners are happy with their solar setup.
    Keep in mind, Nomad (Pxylated) full timed with a group 24 or 27 battery and I think 160 watts of solar.  He is out west though, so sun is typically more available.  It can be done foxden, just be frugal and have a backup plan.
    Last day of a nice Renogy Sale.  20% off a 100 watt monocrystalline suitcase plus another 10% off.  Also nice discounts on the Wanderer controller.  Check it out before it is gone!
    SneakleSneakle Member Posts: 131
    Is there a link for where to buy this suitcase with controller for my new Tab 320s?
    Tab 320s Boondock
    TV: Toyota 4Runner
    Go to Renogy.com
    Sharon thanks for the heads up on that. Ordered one.
    Tab 320s Boondock
    TV: Toyota 4Runner
    Good deal!
    TrailpixieTrailpixie Member Posts: 161
    I found that most of the renogy stuff I bought three weeks ago was cheaper at Amazon.
    These were on sale at the Renogy site for $218 with the Adventurer controller. Looks cheaper than Amazon price regular price. But not sure I'm comparing apples to apples. Voyager controller on some units is waterproof and this one is not. I'll protect it with a bag etc.
    Tab 320s Boondock
    TV: Toyota 4Runner
    It can be done. I do not think he stayed in sites more than 3-4 days, usually, and also barely used the battery.
