Winterizing Issue?
2»
  • BrianZBrianZ Member Posts: 1,768
    edited November 2017
    Forgot to include this shot of how I keep the trap door open while winterizing the pump.  I put a small screw-eye in the wall (there is sturdy plywood there) with a 1.5" metal ring close to where the finger-handle on the open door is located, so it's easy to latch & unlatch.  A piece of string or wire would work too, but I had this nice looking ring left over from the hub of an old computer hard drive I took apart.  Had to bend the handle slightly to give it a bit more of a hook so it wouldn't easily slip off.  I put some caulk on the threads of the screw before screwing it into the predrilled hole in the wall, to keep water from getting into the wood.
  • ScottGScottG Administrator Posts: 5,636
    Hey, that would work a lot better than propping it on top of my head!
    Doctor to patient..."on a scale of 1 to 10, 10 being the greatest, what's your current @ScottGWinterization Worry pain level???  A 10 you say, I recommend you sell your camper each fall and purchase a new one in the spring"    =)  This forum is awesome!
