ALDE worked perfectly for two days (May 25 & 26) On the 3rd morning had no furnace function. Replaced two fuses in the ALDE. All fluids and ALDE controls re-examined, all fuses in the master panel checked o.k. Circulation pump still inop. Water heater portion still heating until it blew all the glycol out thru the expansion tank and then blew the red hose hose at the top of the boiler apart. At this point the water was boiling, scalding hot water and steam everywhere. What, if any, safety controls are there to prevent over heating and over pressurization of the boiler system? and why did they also fail. I was inside with the ALDE unit exposed when things let go. It's a 2015 CSS Max TAB so probably my problem will be swept under the door and filed with a red flag "OUT OF WARRANTY." Not very happy with the TAB anymore, but the 1st two years were fun.
2019 TAB400 2018 Toyota Tacoma 4dr trd off road
0 ·
