That can happen with the whole freeze and thaw process. Mine was like that too.TerryV6 said:I still don’t plan on tv watching while camping. Nice to know it’s an option though. I had a few minutes at noon to mount the antenna part. Not too tough.. However when up there I saw a poor example of caulking. What do think? This weekend I’ll run the cable. Dalehelman, I see you put in an coax elbow. Neat. Did you cut off much extra and put on a new connector?
Gray tracer wire is positive +.ChrisandAlexis said:@Dalehelman, I just received the antenna and was going to cut the AC to DC converter off that powers the 12 volt booster and tap into a 12 volt source somewhere. Can I assume that of the 2 wires going to the 12 volt booster, the one with the gray striping is ground?
I have found that it is not really necessary to get the antenna high in the air. By attaching it to the AC vent I still get good reception and I have nothing to set up or store.
Hi atlasb, I am looking to try Dale’s excellent tv antenna mod on my 400. Would you be willing to post some pics please? I’m only minimally handy and seeing photos helps immensely. I’m guessing the interior tv 12V connection is the same for either the 320 or 400? So only the outside vent mount and cable/over air tv switch. 😊atlasb said:Hey Dale, Thanks for the great mod! Just installed the ant. from your link on amazon. I installed it on our 400 and mounted to the vent stack as you did. Removed the vent cap ( you probably should remove the screw in the little hole in the top first) and ran the cable down through the vent. Accessed the vent stack by removing the panel above the alde tank in the closet and removed the cover for the alde tank. drilled a hole in the vent stack and pulled the cable through. sealed the opening and replaced the panels. fed the cable through the closet beneath the access port into the alde cabinet under the head of the bed. found the out side ant. cable and cut, installing a switch to go from cable to air. cleaned up and placed the booster on the back of the TV. We live in the country with mountains and the only way we get TV is by satellite. I had the 400 in our shop which is a steel master steel building and decided to try and see if it worked. I plugged in the amplifier to 120 volt and ran a channel scan. To my surprise, I got a local station with 3 different HD channels. Can't wait to get out again and see how it works. As they say, Winner, Winner, chicken dinner!
Thanks again,
Fred, Donna, Jaxson and Hoku
