2018 T@B Task List
We’ll be picking up our T@B from winter storage real soon now and I’m putting together my task list for the year.
Weigh tongue (finally got a scale to use)
Install new NuCamp URL decal
Check fire extinguisher recall (pinned post)
NY State inspection, have brakes and bearings checked
Check caulking around floor and seal around front window (pinned posts)
Troubleshoot fridge (did not work on propane last fall)
Replace shower magnet strip
Build and install mirror on front of shower door (acrylic mirror sheet on order)
Move old Chromecast device from house to T@B TV, have unlimited data this year
Dewinterize (weather might be above freezing by the time all of the above is done)
Sanitize fresh water tank
Order and install hepvo trap
Mount sewer hose holder
Replace kitchen faucet
Investigate UpNFront bike mount
What maintenance items and mods are in your plans?
  • jkjenn
    jkjenn Member Posts: 6,424
    I always like to check screws and bolts, inside and out, as they can loosen as you travel. I had the factory do the regular bearing maintenance and safety inspection. (ended up under axle replacement), and aslo recaulk where needed.
    I am also going to:
    1. Remove everything and do a thorough cleaning and remove what is unnecessary.
    2. Probably remove my Jack-E-Up.
    3. Install the spring loaded cabinet latches.
    4. Replace water filter (connects to freshwater hose, external.)
    5. Reprint my shower door decal.
    6. Install bluetooth propane bottle guage.
    I am also considering the Hepvo trap.
  • Photomom
    Photomom Member Posts: 2,217
    I cleaned the interior and took everything out last fall. Hopefully I won’t have had any mouse visitors over the winter and won’t have to do any cleaning. I did think of another item,
    Check for frame cracks and report results to Dalehelman.
  • Homebodyatheart
    @Photomom, I'll add
    Check caulking in shower (found a small gap this winter)
    Make my new Redneck Front Porch
    Restock kitchen items, herbs, canned stuff, etc.
    Add "Other" category to this list (I'm sure more will come to mind!) :rofl:
  • ericnliz
    ericnliz Member Posts: 4,437
    edited March 2018
    Install rear scissor jacks for leveling (with help from @Dalehelman :) )
    Pack bearings & adjust brakes
    Check for frame cracks: Check, no cracks
    Check caulking: check, everything sealed
    Tighten all screws (exterior)
    Take Alde system out winterize mode
    Check battery & propane tank (fill if necessary) :Need propane
    Check functions of fridge & Alde (hot water & heat)
    Hang Liz's memorial disc
    Figure out camping in the WolfT@B without my dear wife..... :s
    Put one foot in front of the other & take one day at a time
    Get ready for the SpoT@B potluck
    Get ready for "The Guy's" camping trip
    Plan for Lincoln Rock Rally
    Get ready for whatever other adventures may come my way..... ;)
    ScottG Administrator Posts: 5,687
    edited May 2018
    Aside from the usual dull maintenance chores, I'd like to make two mods inspired by others here on the forum:
    1) Install a sewer hose carrier, preferably across the frame and behind the tub. I'm eyeballing the "Super-Slider" model as its slightly larger diameter claims to hold the RhinoFlex and its fittings without having to remove the elbow. Anybody have any experience with this model? I dislike having to futz with stuff, so eliminating sewer hose assembly and breakdown would be a major advantage in my book.
    2) Install an upper shelf forward of the rear cabinets. Not sure if I'll build this out of wood or just go the ClosetMaid route. Right now a lot of clothing and other personal items reside on the king-size bed while in camp. The shelf might provide a little flexibility for keeping things corralled.
  • Dalehelman
    By the time you guys get all that stuff done you should have just enough time to get it winterized.
    1. Hash  T@B Fun
  • Photomom
    My goal is to have my list done by our first camping trip the last weekend of April. When you live this far north you can’t mess around.
  • ericnliz
    @Dalehelman, :rofl: You're pretty funny today! Since you go South for a good portion of the winter, & have your T@B parked in your garage where it never gets below 40*, I'd say you're WAY ahead of the rest of us cold weather Northerners! That being said, however, you're right....just about the time I get nice & comfy with the set-up & maintenance, it's time to put it back in cold storage again. :o:s
    This year, however, I plan to get a LOT more use out of it to justify all the planning for Spring & fall!!!
    pthomas745 Administrator, Moderator Posts: 4,654
    edited March 2018
    I can cross off "make a list of things to do to the Tab" off my list.
    These were all useful..thanks!
  • Verna
    Verna Member Posts: 6,876
    I sure hope I find don’t have to winterize after I get home.
  • jkjenn
    You might...winter seem to want to linger this year.
  • ericnliz
    ADD TO LIST: Check Alde plug under driver's side bench to ensure it's plugged all the way in. (Might look all the way in, but it's not & only takes a second to check) =)
  • Photomom
    This is awesome. I figured the brain trust here would add stuff I've overlooked.
    9 days till we liberate our T@B from our friend's barn - who's counting - I'm spending the time planning what I need to and preparing some dehydrated backpacking meals - yes, this works when you have limited food storage space in your RV and you know that sometimes you will just want an easy meal without having to "cook."
    Eric, we used a bendable wire to secure it to the outlet.
  • ericnliz
    @SAM, I just might have something that will work around here somewhere....A-HA...picture hangin' wire should work. =)
  • Lmurphey
    Lmurphey Member Posts: 2
    jkjenn  We are considering a Jack E up. Why are you taking yours down?
  • Lmurphey
    Jkjenn  Nevermind I was thinking of a Jack-It.
  • Homebodyatheart
    Today's accomplishments: topped off the battery with distilled water, took the propane tank for a refill, flushed out this year's water filter, did a few odds and ends to the shed, put the new multi-level hitch together. Need to buy 2 or 3 pin locks for it. Sometime.
    Still need to dewinterize and sanitize the lines before Friday. Other odds and ends as discovered...
  • dragonsdofly
    @Homebodyatheart, wow, it's that warm in the state if Washington? Tomorrow is Easter Sunday and here in Michigan, not far from Detroit, tonight will fall into the teens*F and the holiday is predicted to see the temperature soar to just below freezing. Can't get any of that stuff done on Dr@gonsFly yet. As it's going, may be another few weeks to month before we can get those necessary chores accomplished. Enjoy your "early" spring.
  • jkjenn
    My T@b is at my mom's so she can work out the bug screens for my T@b and also looking to try something decorative withers the window valances.
    I will bring it home sometime next month, probably and it should be warm enough by then to de-winterize....but, it looks like more snow expected tomorrow night!
  • ericnliz
    @dragonsdofly, @Homebodyatheart is getting ready for the pot luck BBQ next Friday. I'm pretty sure there will be at least 3, maybe 4 other trailers there. I'm taking mine, rain , or shine.
