jkjenn
Member Posts: 6,417
2011 T@B
Rockingham, NC
“1 x marine grade 304 stainless steel rod holder with marine grade 316 clamp-on bracket
1 x Rubber insert (fitted)
Tube length 230mm (9")
Inside diameter 42mm
Outside tube diameter 52mm
this is product branded amarine-made“
I had to drill out the plastic bottom so my antenna pole would fit through it. It is very sturdy, but I did not leave it on during travel. You do need a metric Allen wrench to adjust the clamp where it connects to the handle.
2011 T@B
Rockingham, NC
