Has anyone received the nucamp fix for t@b windows? The brush rail kits are out of stock and I saw some “weatherstripping fuzz” in the hardware store. I am wondering if someone can tell me the dimension of the brushes? I might try a temporary fix as we will be heading out to a camping area in the next few days that usually has lots of mosquitos. Thanks
0 ·
Alan & Patty
Southern Az
http://teardrop-trailers.vanillacommunity.com/discussion/222/window-screen-fix
Alan & Patty
Southern Az
2017 T@B Max S Outback (W@y@); TV 2010 Subaru Outback
this was a bit tricky to do. Basic tools required, but patience is a must!
No explanation was provided, but I surmise that the brush, because it is not flexible side-to-side, will not fit easily in the slots of the curved front window.
I'm not sure if the foam will be more or less effective than the brush. For that matter, I'm not sure if either approach will really solve the problem when the midgies are thick, but they certainly can't hurt. I'll give 'em both a try and report back after my first early-season trip to bug country.
Alan & Patty
Southern Az
I'm not sure if I got enough brush to do all three windows. I hope so, even if I have to clip or otherwise modify the backing to fit the curve in the front window. It's not going to help much to to only plug 2/3rds of the gaps...
It also looks like there may be just enough brush to fill all six window edges. Once T@bby is fully out of hibernation I'll do the install and report back. Hopefully I can avoid adding the battery powered vac to the gear collection...
Interesting that you already had the fuzz on your front window but not the sides. My 2015 had nada.
1 Box has enough to complete 1 1/2 windows! lol. Yes, interesting that the front curved window had been upfitted by the manuf. but not the side flat windows. I would suspect that the flat windows will be upfitted by the manuf. in coming model years...maybe 2019?
the black cord cord is on the bottom, so...
1) removed bottom mounting screws(with square head driver)
2) “popped” black cord & set screw from window frame
3) removed Phillips head screw that holds frame together.
at this point, gently separate the corner piece only enough to allow space for bug fuzz to be installed without getting all buggered in the screen edges and enough only to expose the slot where the bug fuzz actually goes. Too much, and you run the risk of the cords becoming unseated from their respective rollers.
4) remove factory installed “spacer” that is in the slot.
5) measure, cut & insert bug fuzz.
6) reinstall corner piece to vertical & horizontal frame pieces.
7)reinstall black cord/setbscrew lug into window frame. A gentle yet firm hand is all that is needed.
8) re attach frame to wall!
repeat on the other side of frame, then move onto the other window.
it is easier then removing the entire unit, etc...I unfortunately started with the passenger side before realizing that I had to deal with the driverside, as I had described.
First off, the front window has massive gaps, all the way around the frame. I was not sent nearly enough foam strip to seal that off, so I decided to leave the front window as is for now. Am I missing something here?
Anyway, I shifted my focus to the side windows. I really did not want to take the window frames off, or apart. I hoped I could just "stuff" the rail brushes (aka "bug fuzz") in place. It turns out, I could.
1. I started by popping off the corner pieces on one side, to clearly see how long I needed to cut my piece. I then cut the brush to length, using household scissors.
2. I inserted the top corner of the plastic base of the brush into the slot.
I then slid that top corner to near the top of the slot. I then used the tip of the scissors, to push in the other top corner of the brush base into the slot, pushing on the plastic base, not the brush bristles. You may wish to use another tool, like a flat head screw driver. I worked my way down a few inches, pushing the base of the brush into the slot with the tip of the scissors. Click click click as it pops into place.
3. Using my fingers to grip the brush bristles, I slid the top of the brush all the way up into the slot.
4. I then repeated the procedure at the bottom end of the brush, being careful to not push the white or black cord into the slot.
5. I continued to work the base of the brush into the slot, finishing near the middle of the brush.
6. Finally, I tested the screen and shade operation. Everything still slid smoothly. The only change I noticed was that on the one window, the friction of the brush caused the screen to not accordion perfectly uniformly at the top. It can be straightened out in just a couple seconds if desired.
7. The end result is that bugs will indeed have to work a little harder to get though. Will it be completely bug proof? I'm not sure, but it will certainly be better. I suspect it will defend against mosquitoes pretty well, but smaller pests found in some areas might still find a way. Time will tell.
I am not necessarily endorsing this installation method, or suggesting you do it the same way. I am simply sharing what I did. I encourage you to use your own good judgement before choosing your approach.
I'm not yet giving up on my plan A to replace the screens entirely with something more functional. Once bitten, twice shy applies here--ha ha.
@RollingBnB, @4ncar, and @rkj__, thanks again for your input and I await your reports from the field!
2016 T@B S Max (H@banero) - 2025 GMC Canyon Denali - Magnolia, TX
