I'm guessing you carry a multimeter too, so if you still have the circuit board, it would be interesting to know if F2 is the culprit.Verna said:@ChanW, I was working with Marvin and we agreed it would be quicker for me to replace rather than troubleshoot any longer. We never discussed replacing a soldered fuse, and I do carry an inexpensive soldering iron. After all, I was without heat, and even AZ gets cool at night. Thank goodness I always make room for a compression sack with my sleeping bag inside
But anyway, no, the circuit board was not sent back to Alde. After working with different circuit boards for most of my career, I’m always curious about burn marks showing what failed. The phone company never allowed us to replace anything soldered on a circuit board, preferring to allow those companies with a static free environment to refurbish the circuit boards. (I cringed at how many of my co-workers treated the circuit boards without regard to possible damage by static electricity.)
Where did you find the directions to do that?jumped the thermal fuse on the control board, and it fired right up.
It was in the link Hobien provided above. Good to know in a pinch, since it appears to be a fuse that fails over time from fatigue. I'm planning on putting in a resettable fuse, will post pictures when it's done.jkjenn said:Where did you find the directions to do that?jumped the thermal fuse on the control board, and it fired right up.
Following...seems like a really good idea.db_cooper said:It was in the link Hobien provided above. Good to know in a pinch, since it appears to be a fuse that fails over time from fatigue. I'm planning on putting in a resettable fuse, will post pictures when it's done.jkjenn said:Where did you find the directions to do that?jumped the thermal fuse on the control board, and it fired right up.
Ours has that too. It is a unique little "quirk". At first, I thought it was part of the Alde vent system but then I looked under the bench and saw it went nowhere and just laughed. It was probably installed in all the walls by default but when they switched to Alde, they already had the walls made.ChanW said:Yes, ours is one of the first that Little Guy installed the Alde in. Our driver-side wall even has the hole cut in it for the old style furnace exhaust, right next to the Alde exhaust.
https://www.digikey.com/en/products/detail/cantherm/SDF-DF091S/1014756?s=N4IgTCBcDaIMwEYDsBaBCyoHIBEQF0BfIA
@Photomom ironically, that link is "faulty," lol. I'd like to read that article but couldn't find it on their site. Do you have a good link? TIAPhotomom said:Here’s a very interesting article about the ethics of thermal fuses (they contribute to the problem of repairable products being sent to landfills). At the end of the article there’s a suggestion to crimp the new thermal fuse in place instead of soldering.
http://www.evonet.com/evonet/index.asp?Page=34&ID=34
