Two 6 volt batteries in the tub of the 2016 T@B S 320 - No Way!
People on the forum have said they have put 2 batteries in the tub, but I cannot see anyway it can be done. I have made a cardboard template of the batteries:
  • Length: 10.25 in
  • Width: 7.125 in
Even with ignoring the propane connector and the power switch I have tried every way of placing the batteries and no go. I know it can work in the Outback version, but not mine. The only thing I can figure is that some of the standard tubs are larger or that the tub is moved forward making more room. Is this like a rubik's cube and I have just not figured out the magic formula or what...
Mickey & Terri
2016 Max S
Kalamazoo Michigan
    • Length: 10.25 in
    • Width: 7.125 in
    6 volts vary in size. My Trojan T105+ batteries would not fit in the Outback tub without modification.
    @mandt, the standard tub gets moved away from the trailer.  We have a single, large AGM and that is how the factory made room.  I saw a pic of another one somewhere on the forum where they moved the propane holder and made more room.  Verna has 2 6 volts with the standard tub, too.
    @SAM, I have the diamond plate larger tub. I moved the propane tank to the middle and I have a battery on either side of it to balance the load. The wiring is not as neat as when they are dude by side, but they work just fine.
    @cbarnhill has a standard tub with two 6-Volt batteries do they will fit in the standard plastic tub. Do a search for cbarnhill and you will find her post.
    Oops.  Didn’t you originally have 2 in the standard tub?
    @SAM, no. I changed to the diamond plate tub within weeks of purchasing the T@B, although it took me over 5 months to get the welding completed to put the propane tank in the middle, and to then install the batteries.
  • AMslAMsl Member Posts: 6
    Just completed my twin trojan 6v install in the Outback tub. Initially the cardboard footprint of the batteries showed the batteries would not fit, close, but no cigar. If I moved the tank holder, I would gain enough, only needed a 1/2". I found that I only had to grind the welds of the holder leg closest to the batteries. This was good because I was sure the grinder would not  fit in to  grind the welds of the other holder legs. I reattached the holder leg, about 3/4" from its original position, using aluminum rivets, the propane tank still fits in fine. Made up some brackets from some aluminum angle stock I had, attached these to bottom of tub with rivets as well.
  • JdcoupleJdcouple Member Posts: 96
    Thank you so much. This is one of my next serious mods.
  • mandtmandt Member Posts: 158
    Unfortunately I do not have the Outback.
    Mickey & Terri
    2016 Max S
    Kalamazoo Michigan
    @mandt, I think @Ron has 2 6 volts in his tub and an upgraded propane tank - the kind you can see through.
    Nevermind- he has the upgraded tub.
  • cbarnhillcbarnhill Member Posts: 330
    Sam- i have the standard tub and i have 2-6volt batteries in there. They had to move the propane tub slightly and make a stand for the batteries. Here’s a picture.
    Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)
    Thank you @cbarnhill.  I knew there was one out there somewhere!
    I think key is to measure and make a template with the dimmensions of your batteries.
  • PGSUtahPGSUtah Member Posts: 9
    @AMsl   can you please post of pic of the configuration of the battery wires on two 6 volts.   Just got mine and need to be sure I'm doing it correctly
    thanks
    edited May 2018
    https://www.etrailer.com/question-60431.html
    What year and model trailer do you have?  Do you have the solar port on the tub?
    thank you   2017 Outback
    edited May 2018
    And yes I do have solar (Zamp) port in the tub.  Does that make a difference in hooking it up correctly?
    I am not sure if the solar hook up is different with 6 volts.  Jenn, Verna can you comment here?
    edited May 2018
    I have the Zamp 160watt panel and controller, along with two 6 volt batteries connected in series as shown.  Works great!  I even have the same Duracell batteries.
    The solar should hook to the same terminals as the wires running into the T@B. From your photo it looks like that's exactly what you have done!
    One thing I missed in this discussion about the 2 - 6 volt batteries is the weight.  While perhaps they will fit in a standard 320 tub, I see they run about 60 pounds a piece, for a total of 120.  That’s a lot of tongue weight.  Bikes, spare tire... no can do...
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
    @TerryV6, any extra weight that is added to the tongue can be counterbalanced by putting more of your load in the Tab behind the axle.
    Just have to get more canned goods!  =)
    Hmmmm...  my wife won’t tell me her weight..  grin
    Seriously, I guess I’ll have to get out my hitch weight thingy and do some recording of weights with different configurations.  In the past, we’ve tried to have our camper in camping ready condition.  We could just unhitch, drop stabilizers and go in and make coffee.  Our first camps when we purchased the T@b, we had stuff inside that we had to unpack. We wanted to get away from that.  I’ll have to see what I have to counterweight with...
    T@bbey  Road
    Appleton,  WI
    @TerryV6, we were concerned about tongue weight limits, as well.  In the end, we decided that an AGM was the most important factor (limited maintenance, very low self discharge rate, tolerated creative positioning, etc) and we chose an expanded, but, middle of the road amp hr (150).  It weighs 96# - so 25# less than two 6V.  The clams have a 12 to 15# heavier tongue weight to begin with, so we had to factor that in, too.  Funny, with the kitchen in the rear, you would think the tongue weight would be less than the S model, so maybe the slight axel position difference accounts for that?  Our tongue weight is 225# and that includes a full lpg tank, a second lpg tank, and our Brahma wheel lock forward of the axel, plus other gear carried on the floor between the benches.
    I've got it.. I used to do a lot of scuba.  The lead weights from my belt.  Add or subtract...Grin..Well, I guess not, my weights were only about 20 pds total.
    T@bbey  Road
    Appleton,  WI
  • CherokeeCherokee Member Posts: 318
    I'm not sure this will be my finial solution, but a tight fit is generally always better then a having something moving around. Though my batteries wouldn't fit on the bottom, there is enough flex in the box to allow fitting one on the bottom and another on a 4x4. The stepped solution allows the batteries to both fit well secured. . I added a cord across the top to assure they stay in place on bumpy dirt roads:
    California, USA
