Isn't the ducting and venting different on the new fridges? I'm not sure if you could adapt it to the original openings, or if you'd have to do some cut and patch work on the T@B walls.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
The two front vents would need to be sealed and an additional vent cut in the side. At a minimum. I suspect at some point people will start replacing the 3163s with newer model fridges. I don’t want to be the first though.
@Photomom, this would be a good question to send to tech@nucamprv.com. A very nice and knowledgeable young man answers the questions sent to this email address.
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
Alan & Patty
Southern Az
Alan & Patty
Southern Az
