FJ Cruiser to Tow a T@B 320CS-S
TFL2018
Member Posts: 9
I am thinking about purchasing a T@B 320 CS-S and have a 2012 FJ Cruiser. It has a 4700lb towing capacity. Does anyone tow their T@B with a FJ and if so have you had to add anything or does it tow this trailer fairly well? Thanks
There was an owner on here who did not like the way his/her FJ towed the T@B. If you search for “FJ” in the above search box, you should be able to find their comments.Verna, Columbus, IN
Thanks, I took a look and the owner indicated said it tended to fishtail at higher speeds. I appreciate the heads up.1
I can’t answer the question, but the very first time I saw a picture of a T@B it had yellow trim and was being towed by a yellow FJ Cruiser and was owned by a traveling photographer. I was, needless to say, very taken by it and immediately showed the picture to my DH.John and Henrietta, Late 2016 T@B S Max in Western New York0
Awesome! Thank you
Saying that a T@B is fishtailing behind a FJcruiser is like saying it is also fishtailing behing a 1 ton pick-up truck. Not enough information and trouble shooting info to make that a fact.
Fishtailing is always related to weight (load) repartition and center of gravity.
A T@B or a T@G behind a FJcruiser would make an awsome set-up if you ask me.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC2 -
@TFL2018, the FJ Cruiser owner was towing a Boondock (Outback). Different center of gravity. I suspect you will be fine with the CS.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
This is the set up SUNT@Bs first owner had.
3 -
We have a 2017 Max S and use to tow it with a 2008 FJ. It did tow and handle ok but really drank the gas while towing. Traded it in last year and now tow with a F150.Linda & Dan
Cleveland, Ohio
2018 Ford F150 XLT pulling a 2020 T@B 400
LIFE IS GOOD!0 -
Thanks very much. Makes total sense0
Been towing with my 2008 FJ for years. Never had a single problem with the FJ nor with the towing. No add ons other than Reese tow hitch and Toyota wiring kit which I had to adapt to get the 7-pin receptacle. I do think a transmission oil cooler would be beneficial but I have not yet added one. My gas mileage ranges from 13-16 depending upon terrain.
Stancil Campbell
2011 T@B
Rockingham, NC
This is exactly what I needed. Thank you very much0
- 920 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
