FJ Cruiser to Tow a T@B 320CS-S
TFL2018
TFL2018 Member Posts: 9
I am thinking about purchasing a T@B 320 CS-S and have a 2012 FJ Cruiser. It has a 4700lb towing capacity. Does anyone tow their T@B with a FJ and if so have you had to add anything or does it tow this trailer fairly well? Thanks
  • Verna
    Verna Member Posts: 6,876
    There was an owner on here who did not like the way his/her FJ towed the T@B. If you search for “FJ” in the above search box, you should be able to find their comments.
  • TFL2018
    Thanks, I took a look and the owner indicated said it tended to fishtail at higher speeds. I appreciate the heads up.
  • Photomom
    Photomom Member Posts: 2,217
    I can’t answer the question, but the very first time I saw a picture of a T@B it had yellow trim and was being towed by a yellow FJ Cruiser and was owned by a traveling photographer. I was, needless to say, very taken by it and immediately showed the picture to my DH.
  • TFL2018
    Awesome! Thank you :)
  • Luckyj
    Luckyj Member Posts: 286
    Saying that a T@B is fishtailing behind a FJcruiser is like saying it is also fishtailing behing a 1 ton pick-up truck.  Not enough information and trouble shooting info to make that a fact.
    Fishtailing is always related to weight  (load) repartition and center of gravity.
    A T@B or a T@G behind a FJcruiser would make an awsome set-up if you ask me.  :)
    TV 2005 jeep TJ unlimited
    Alaskan Malamuthe on board!
    Les Escoumins and Petite-Riviere-St-Francois QC
    @TFL2018, the FJ Cruiser owner was towing a Boondock (Outback).  Different center of gravity.  I suspect you will be fine with the CS.
  • rfuss928
    rfuss928 Member Posts: 1,196
    This is the set up SUNT@Bs first owner had.
  • DINDAnLAN
    DINDAnLAN Member Posts: 75
    We have a 2017 Max S and use to tow it with a 2008 FJ. It did tow and handle ok but really drank the gas while towing. Traded it in last year and now tow with a F150.
    Linda & Dan
    Cleveland, Ohio
    2018 Ford F150 XLT pulling a 2020 T@B 400
    LIFE IS GOOD!
  • TFL2018
    Thanks very much. Makes total sense
  • Estancio
    Estancio Member Posts: 243
    Been towing with my 2008 FJ for years. Never had a single problem with the FJ nor with the towing. No add  ons other than Reese tow hitch and Toyota wiring kit which I had to adapt to get the 7-pin receptacle. I do think a transmission oil cooler would be beneficial but I have not yet added one. My gas mileage ranges from 13-16 depending upon terrain.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • TFL2018
    This is exactly what I needed. Thank you very much
