400 fold down sink not draining well
On my first use of my camper,  the  bathroom sink was not draining well.  The water pump was on and I did hear it kick on briefly when I turned the sink on.  When I folded the sink up a bit,  it seemed to drain better.  The kitchen  sink and shower drained fine.  Any thoughts or something I need to do?
2018 T@b 400
«13
  • Haloo
    Haloo Member Posts: 137
    Ours doesn't drain quickly either. And I tilt it up a bit to get it to drain completely. Otherwise, we love the sink and the fact it folds out of the way.
    T@B 400 | F150 | Washington State
  • gooddogs74
    gooddogs74 Member Posts: 76
    @Haloo, does water sit in yours for 10-15 minutes and not move?
    2018 T@b 400
  • Verna
    Verna Member Posts: 6,876
    Here’s a hint from the Cirrus Truck Camper FB Page on how one owner deals with the fold down sink:
    “Tip the sink back and forth several times to allow as much to drain as possible, then swipe the bowl with an absorbent cloth like xxxxx suggested. I stuck a command hook right next to the sink so it is handy. We've not had water on the floor since, except after a shower. For that we try to park so that gravity helps aim all the water towards the drain in the floor, the wipe out excess“
  • gooddogs74
    @Verna so is this considered normal? I am new to campers so it seems strange to me that it is normal for a sink to just not drain without extra work being done to make it do so.
    2018 T@b 400
  • Haloo
    @gooddogs74, this is pretty much what we do. The drain hole is small, which doesn't help.  But even though it doesn't work like a sink at home, we are okay with it.
  • 4ncar
    4ncar Member Posts: 1,072
    Could it be improperly vented? Even with a small drain hole, if vented correctly it should drain.  What does nucamp have to say about this...?
  • LSkrabut
    LSkrabut Member Posts: 136
    My 400 folding sink does the same slow drain act. Only for 30-60 seconds with only a small amount of water. The last bit is a lot slower than a sink 1/3 full. Also a slight lift, drains faster. I do wipe the sink down after ever use.
    Utah Driven
    2019 T@B 400 (Ex 2018 400)
    2015 MB GLK 250 Diesel
    2018 GMC Canyon Denali Duramax CCSB
  • tbbycat
    tbbycat Member Posts: 7
    That looks great!
    t@b400 / Chevy Colorado
  • Justin_in_Seattle
    Justin_in_Seattle Member Posts: 47
    Tabfortwo said:
    I finally got around to fixing the bathroom sink In our 400 now it drains.
    That looks great.  I wish it was a factory option. The slow draining bathroom sink is one of my biggest complaints about our 400.
    2018 nuCamp T@B 400  +  2016 BMW X1 tow vehicle
    Has anyone figured out why the fold down sink drains slowly?
  • Verna
    The drain is flexible on the sink, too flexible and it prevents water from exiting quickly. I did share this discussion with nüCamp and they were impressed with the simplicity of the replacement sink.
  • Tabfortwo
    Tabfortwo Member Posts: 157
    edited August 2018
    That is a toad brush that you wipe your shoes on outside. Which is currently being stored in the bathroom
  • gooddogs74
    Just updating here regarding my sink.  Towed my trailer the 3+ hours to the dealer for warranty work.  The sink drains now.  I was told various things depending on who I spoke with at the dealer.  The man who fixed the sink apparently had to disassemble everything.  He said the pipe and drain hole were small.  He said it went UP instead of down in one place.  I also heard from a service advisor that there was debris in the pipe from the manufacturing process.  My paperwork noted a kink.  So not really sure if some or all of these things were the problem, but it does drain now.  It is not super fast, but it drains without lifting it up and down a million times.  Maybe my husband will stop brushing his teeth in the kitchen now.  @Tabfortwo that looks really nice!
    2018 T@b 400
  • BigGrover
    BigGrover Member Posts: 450
    Tabfortwo, any pics of the wall and what you used to mount the sink on.  Is it plywood?
    BigGrover
    2019 T@b 400 Boondock Lite
    2018 Ram 1500 Quad Cab Hemi
    Central Alabama
  • Tabfortwo
    I removed the old sink cut the 1.5 vent pipe to insert my drain line. Removed the 3/4 couragated hose and patched the hole. Cut a piece of plywood to fit the opening. installed a matching piece of plastic panel then in stalled sink to the wood.
  • gande
    gande Member Posts: 105
    Tabfortwo...Your modification looks great! Where did you source the sink from?
    gande
    2018 T@b 400
    2019 Ram 1500 crew cab / 5.7 V8
  • Tabfortwo
    Amazon
  • gande
    Do you know the brand name or model number?
    gande
    2018 T@b 400
  • Tabfortwo
  • gande
    edited February 2019
    Thank you.  The slow drain on the factory sink is very annoying so I'm considering doing your upgrade.
    gande
    2018 T@b 400
  • Tabfortwo
    It's the best upgrade I've done
  • johnny_swindle
    johnny_swindle Member Posts: 19
    I love your upgrade.  Where did you get the matching piece of plastic?
  • Tabfortwo
    Home depot
  • Cbusguy
    Cbusguy Member Posts: 771
    edited March 2019
    that is a great find,   thinking the spigot on the left side might be nicer,  but a more functional sink is a win
    or do the water lines come into the sink on the right side.
    2009 GMC Canyon,   3.7 liter
  • Tabfortwo
    They sell the sink with the faucet on either right or left application. The water lines are long enough to reach either side.
  • Michigan_Mike
    The factory is installing a rectangular style fold down sink on the new 400's and this should correct the drainage problem.
  • Tabfortwo
    If it's the same 3/4 couragated pipe I don't that being any better. I reconfigured mine in many different ways and materials nothing made it better. Having to lift up and down on the sink to make it drain is not the answer.
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    @Michigan_Mike assuming the 2020 sinks work better, would they easily swap into previous year 400's or is that unknown?
