I literally just paid the previous owner, hooked it up to my TV and got it home. It has been sitting since new and I couldn’t get anything to come on just on battery.
Once I plug it in, it lights up like a Christmas tree. Yes, I made sure the battery is in the on position. Just wanted to make sure there was nothing else I was missing that I should be flipping on. There is also another set of battery leads. I’m assuming that they are for the solar panels?
Since I plan on camping this weekend, I ordered the Amazon special
https://www.amazon.com/gp/aw/d/B00S1RT58CPlease let me know if there is something obvious that I’m missing. Thanks!
But battery could be totally gone...frozen last winter, now shorted out between plates maybe?
Not sure about extra battery leads...from factory they have two wires on each post. Two main ones, plus two that go to Zamp port. If you have 3 sets...well yes prior owner added something that is no longer there.
I have a trickle charger and I’ll put it on that. I do have a spare battery in my boat that I can try to hook up.
The terminals on the lead connected to the battery were extremely corroded and not well attached so I cleaned them up with a wire brush and have the battery on a trickle charger. It is probably dead but it can sit there on charge and it won’t hurt it. Now to go figure out the tank flushing.
It's worth checking. However, If I was a gamblin' man I'd cast my lot in with the "battery is toast" crowd!
If you do flip the wires, make sure you take off the "Zamp Ready" sticker!
In my case, my Renogy kit didn't even have any SAE quick connectors. Since I had to splice in my own, I just spliced it to match Zamp's polarity.
I guess I will borrow a battery from the boat if I hit the road before the battery comes in. Most trailer batteries seem to be bigger than the little thing that came with the Tab. I'm assuming when people upgrade they modify the the battery box to accommodate the larger battery.
2017 Toyota Tacoma with tow package
Pacific Northwest
I left it on a trickle charger for a day, cleaned the connectors with a wire brush, put some dialectic grease on them, and the battery works like a charm.
I have no idea if it was totally dead or if the lifespan is diminished but it seems to work now. I did buy a generator as I have a baby and need to have the ability to control the temp if it gets too hot but for now, it seems we are good with the OEM battery.
But good luck. I'm happy to lose that bet if it means you get a good battery! :-)
How long will a battery typically last with LED lights and fan on? Would be good to know as I can test if my battery is holding a normal charge. Maybe tonight I will run it longer.
You will learn how to think about how many amps does my battery have, how many amps does this item use, how many amps do I estimate I have left, etc.
https://jenngrover.com/2016/01/guilty-as-charged-rv-battery-use-management-part-ii/
I usually judged based on how well the unloaded battery takes and holds a charge. After a full charge--and some time for the "surface charge" to dissipate--a good battery should settle in at >12.6V. Completely disconnected it should retain that charge for several days or weeks.
An ailing battery with won't charge up fully, or the charge will drop rather quickly. The sicker the battery, the more obvious these effects will be.
I had one that was so bad I could watch the charge dissipate in real time after I took it off the charger. It would eventually settle in at ~10V. Serious toast.
Battery held up for three days running all systems and the fan. Just couldn't run the AC or the toaster.
You may wish to get a camp toaster. They allow you to make toast over the propane stove burner.
We've slept in 34 states, 2 countries & counting.
