Power for the ARB portable fridge AND the Norcold while in transit
Tabaz
Member Posts: 2,421
Well this was interesting. I set my Norcold to DC and hooked up my ARB in the TV to one of its 12V outlets before leaving on a 13 hour trip. Both the ARB and Norcold were pre-cooled for 24 hours before leaving. Upon arriving at camp 13 hours later, I noticed my trailer battery was down to 57% of full. The ARB worked flawlessly during the trip (staying at 27*). The 7 Pin connector on my TV does have the power line to the trailer to charge the battery while in transit. However, the ARB must have used all the juice that would have gone to the trailer battery. On the return trip, I turned off the Norcold and only kept the ARB on. Battery was 59% upon leaving the camp. Upon returning home 13 hours later, it was 98%. Moral of the story is that I can't use both the ARB and Norcold while in transit. Looks like I'll need to get a separate battery for the ARB in order to run both.
That’s odd... two trips for me(one for 9 days, the other for 3) where I had the fridge/freezer plugged into the 12v in my TV and had the Norcold running in the tab...no issues...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
I noticed that it was too much, combined with my phone. This is why I did the whole GZ Yeti and solar on my roofrack set up. When on DC it should be able to run nearly indefenitely. The ARB fridge DC plug is too long. GZ is aware and will send you an adapter at now charge. They are working on changing this in future versions.Tabaz said:Well this was interesting. I set my Norcold to DC and hooked up my ARB in the TV to one of its 12V outlets before leaving on a 13 hour trip. Both the ARB and Norcold were pre-cooled for 24 hours before leaving. Upon arriving at camp 13 hours later, I noticed my trailer battery was down to 57% of full. The ARB worked flawlessly during the trip (staying at 27*). The 7 Pin connector on my TV does have the power line to the trailer to charge the battery while in transit. However, the ARB must have used all the juice that would have gone to the trailer battery. On the return trip, I turned off the Norcold and only kept the ARB on. Battery was 59% upon leaving the camp. Upon returning home 13 hours later, it was 98%. Moral of the story is that I can't use both the ARB and Norcold while in transit. Looks like I'll need to get a separate battery for the ARB in order to run both.
@Tabaz , what gauge wire is your 7 pin charge line?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Sam - the owner's manual states a 30A fuse for the "Trailer Tow Battery Charge," and 25A for several light relays.2016 Outback 320
The problem with some newer vehicles (mine) is that they are sophisticated to the point where they reduce juice to the 7 pin connector or auxillary outlets to spare the TV battery. It is likely not a charge wire issue.
Didn't someone do some experimenting with the Norcold by increasing the wire size and wiring it directly to the battery? I tried running the Norcold in transit in my Silverado and it drew the battery down below 50% but it recovered quickly once I switched back to propane.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
I recall a post where someone mentioned having the headlights on made a difference.2016 Outback 320
Maybe dsatwork did that wiring?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
@Michigan_Mike, This is the one.
Turbocharging the Norcold N 180.3 3-Way Fridge (beefing up the 12 volt system)
It seems to depend on the vehicle. Some report that turning on the headlight forces an increase in the vehicle's generator output. Unfortunately, I've found that trick does not work on my 2015 Frontier.Tabaz said:I recall a post where someone mentioned having the headlights on made a difference.
@SAM that thread addresses increasing cooling in the new fridges.SAM said:@Michigan_Mike, This is the one.
Isn’t the issue still voltage drop on the way to the Tab battery and frig?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Do you know if your power line in the 7 pins is direclty hook up to the battery of the TV?
and the minimum line should be 10 gauge and heavier. You could be on the same circuit inside TV and power to trailer. But the ARB is a totaly different monster than the norcold. ARB is among to most efficient portable frid out there will work on my jeep battery for 4 days, and still start it w/o issues. I never pre cold mine. Even when empty, will cool down to near freezing in 1/2 hour. But has the travel cover and never in the sun. And my jeep wrangler never have the aquarium /solar oven effect of a close car.
And I will do the larger size wire direct fridge to battery connection in the T@G with 10ga.2017 T@G Max Outback "Le Refuge"
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC -
I think in my case and @Tabaz 's cases it is distribution of power from the TV and also the amount of energy the Norcild uses in DC (over 11 amps/hour.)SAM said:Isn’t the issue still voltage drop on the way to the Tab battery and frig?
Tabaz, also, the ARB fridge 12v plug is a little longer than your average accessory and might not be getting a good charge from your outlet. A lot of folks will run a 12v line, directly the TV battery for the ARB. I could actually do that without too much difficulty as my TV battery is an AGM, located under the front passenger seat.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
@jkjenn, in the battery direct hook-up, go with at least 10ga, wires. You will reduce power loss.2017 T@G Max Outback "Le Refuge"
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
