The T@b owner's manual indicates that tire pressure for the stock tires should be about 35 lbs. I upgraded to the Outback tires. Any reason I should use a different PSI than 35 lbs? Both indicate PSI of 50 lbs on the tires, themselves.
0 ·
The 50 lb. is for maximum trailer load, I think. If you have your trailer loaded to its max and run 35 lb., the tires may not handle the load. I have found in my research that there is much disagreement on this subject.
I can give you my experience. I ran my original tires at 35 lb. the first year. The tires wore and pitted on the outside, indicating they were under inflated. I recently put new tires (changed to radials) on after just over 3,000 miles because I didn't feel safe with them. The new tires have 45 lb. I have only made one trip with them, but they seem to be doing fine. I tend to load it a little heavy. I will keep a check on them and if they start to wear uneven in the center, I will deflate a little.
Happy Trails Y'all
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Central Alabama
You should have no problem deflating them as long as you are travelling at low speed. I regularly deflate my Jeep tires (Radials) to under 10 psi for the entire day while 4-wheeling. But you have to air them back up if you plan on going faster than about 10mph. Bias ply tires are especially susceptible to overheating if under-inflated and run at higher speeds. When I ran bias ply tires on the Jeep, I aired down to about 5psi....
FYI, my regular 320 tires are radials (2016)
2016 Max S, 2011 Volvo XC60
I know my little bitty teardrop bounced from here to kingdom come with the tires at the proper pressure, but the solution was to put a little more weight over the axle, not under-inflate the tires.
Thanks for all the comments! A few other items I learned: Avoid sharp turns with the tires deflated (best to go in a straight line). Carry a ratcheting strap in case the bead comes off the rim (my Grabbers are tubeless, so yes). Wondering if I need to air-up the tires upon arriving at the campsite. The tires may still be warm from the trip (asphalt and washboard)? Not sure I'd want to camp for an extended time with the deflated trailer tires.
2019 Ford F-150 3.5L Ecoboost with Long Bed
