First pics of my new 400 Boondock Lite!
NCNative
NCNative Posts: 95
edited June 2018 in Introductions
I pick it up in July when I can get out to Ohio. The dealer sent these to me today. I plan on using it for the first time at Ucamp18
N@VENOTSE
SF Bay Area
  • jkjenn
    jkjenn Posts: 6,424
    Aweseon! First 400 Boondock I have seen!
  • TerryV6
    TerryV6 Posts: 1,101
    Very nice Camper!  Congrats!
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
  • Tabaz
    Tabaz Posts: 2,420
    Congratulations! I wish you many quite, peaceful hours around the campfire.
  • NCNative
    NCNative Posts: 95
    Thank you! I am looking forward to using it, and meeting all of you at Ucamp18
    N@VENOTSE
    SF Bay Area
  • dragonsdofly
    dragonsdofly Posts: 1,928
    @NCNative, congrats and see you there!
  • 4ncar
    4ncar Posts: 1,072
    @NCNative nice! Looks like the boondock/outback diamond plate battery box is yet to be installed and is inside the trailer. Will it also have 5he outriggers?
  • NCNative
    NCNative Posts: 95
    @4ncr I understand the Boondock light comes with the rugged tires, higher axle, and diamond plate LP cover. It won't have all the equipment that the 320 Boondock has. I am ok with that as I am needing higher clearance more than anything. I can also add modifications in the future if I find myself needing them.
    N@VENOTSE
    SF Bay Area
  • ericnliz
    ericnliz Posts: 4,437
    Very nice! Enjoy! :)
  • George101
    George101 Posts: 48
    What makes it "Lite" - How much does it weigh?
  • NCNative
    NCNative Posts: 95
    @George101, if I recall correctly, it does not come with the utility platform on the tongue, it has off road wheels, and a higher axle.
    N@VENOTSE
    SF Bay Area
  • Verna
    Verna Posts: 6,876
    @NCNative, by the way, according to Creed at Tech@nucamprv.com, the top of the ball on the hitch should be 20” from the ground on the T@B 400 Boondock or Boondock Lite.
  • How much more clearance dos it have over the standard 400?
  • George101
    George101 Posts: 48
    I was just wondering if it was a lighter tow weight than the standard 400.
  • NorthIsUp
    NorthIsUp Posts: 197
    Is that a light just above the steps?
    Jean & Arnie  Nevada
    2019 T@B 400 BL
    2021 Toyota Sequoia 4WD
  • Verna
    Verna Posts: 6,876
    @NorthIsUp, it sure looks like it. Hopefully it is motion activated.
  • Verna
    Verna Posts: 6,876
    @George101, there is no front platform, like on the T@B 320 Boondock, by the way. I do not know for sure if there is a weight difference between the Boondock and the Boondock Lite.  Here is a dealer’s list of the specs for a Boondock Lite. Of course, they may not be entirely correct, but it was what was listed for one of their Boondock Lite models:
  • maddmike
    maddmike Posts: 137
    Dealer told me that the 400 Boondock will not have the platform due to tongue weight issues (the reason why the battery was moved) as they fear owners will overload the platform and make the tongue over 500lbs. Not sure if he knows what he is talking bout but I have yet to see a 400 with a platform.
  • Verna
    Verna Posts: 6,876
    No Boondock platform will be offered on the T@B 400 due to tongue weight concerns.
  • sunshine
    sunshine Posts: 23
    What is the white square "vent" between the wheel and access door?
    2018 TAB400 - M@ry-Christine, White/Black, 2017 Chevy Silverado 2500HD, White
  • That's the battery box vent.
    Pat, Steve, Rowdy & Shadow
    2018 T@B 400 - "T@KO T@B"
  • NCNative
    NCNative Posts: 95
    I plan on taking delivery of my new trailer July 16 and heading straight to UCamp18. I have yet to see my T@B in person, and these are the only photos I have. I am excited I will see it in two and a half weeks! @Verna Thank you for the information on the hitch height, it is extremely helpful!
    N@VENOTSE
    SF Bay Area
  • So did you ask on axle height, or trailer body compared to regular trailer 400? Doesn’t have to be much but here in Utah I’ve seen clearance issues... I wouldn’t change much on mine but this is a great start. Next would be tp dispenser built in to sink🤔
  • Ok at nucamp the sales guy stated that the axle height is somewhere between 2 1/2 to 3 inches higher. They put an off-road tread tire on. They did not change sidewall strength from the old style. Personally the tread doesn’t matter unless u put power to it. When u go off road and u watch side wall flex I would strengthen that. I know how I’ll order mine. Do we need bounce in tire for softer ride while driving so it doesn’t rattle it apart? I’m in my first year of trailer camping. U can also order trim in multiple colors that our dealers should have the color chart for. Not mine. The wheel well and fender changed size a bit to accommodate the on off of a tire.
    Sharon_is_SAM Posts: 10,035
    @Drewcarrie, not sure what you need to know, but the 400 boondock may give you more clearance, it was not designed for rough, off-roading.  Did you mean you were not given the opportunity to order a select color?  How will you order your 400?
