First pics of my new 400 Boondock Lite!
NCNative
Member Posts: 95
I pick it up in July when I can get out to Ohio. The dealer sent these to me today. I plan on using it for the first time at Ucamp18N@VENOTSE
SF Bay Area
SF Bay Area
Aweseon! First 400 Boondock I have seen!
Very nice Camper! Congrats!Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI -
Congratulations! I wish you many quite, peaceful hours around the campfire.2016 Outback 320
Thank you! I am looking forward to using it, and meeting all of you at Ucamp18
N@VENOTSE
SF Bay Area -
@NCNative, congrats and see you there!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
@NCNative nice! Looks like the boondock/outback diamond plate battery box is yet to be installed and is inside the trailer. Will it also have 5he outriggers?TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
@4ncr I understand the Boondock light comes with the rugged tires, higher axle, and diamond plate LP cover. It won't have all the equipment that the 320 Boondock has. I am ok with that as I am needing higher clearance more than anything. I can also add modifications in the future if I find myself needing them.N@VENOTSE
SF Bay Area -
Very nice! Enjoy!
Eric aka: Lone Wolf -
What makes it "Lite" - How much does it weigh?
@George101, if I recall correctly, it does not come with the utility platform on the tongue, it has off road wheels, and a higher axle.N@VENOTSE
SF Bay Area -
@NCNative, by the way, according to Creed at Tech@nucamprv.com, the top of the ball on the hitch should be 20” from the ground on the T@B 400 Boondock or Boondock Lite.Verna, Columbus, IN
How much more clearance dos it have over the standard 400?
Is that a light just above the steps?Jean & Arnie Nevada
2019 T@B 400 BL
2021 Toyota Sequoia 4WD -
@NorthIsUp, it sure looks like it. Hopefully it is motion activated.Verna, Columbus, IN
@George101, there is no front platform, like on the T@B 320 Boondock, by the way. I do not know for sure if there is a weight difference between the Boondock and the Boondock Lite. Here is a dealer’s list of the specs for a Boondock Lite. Of course, they may not be entirely correct, but it was what was listed for one of their Boondock Lite models:
Dealer told me that the 400 Boondock will not have the platform due to tongue weight issues (the reason why the battery was moved) as they fear owners will overload the platform and make the tongue over 500lbs. Not sure if he knows what he is talking bout but I have yet to see a 400 with a platform.
No Boondock platform will be offered on the T@B 400 due to tongue weight concerns.Verna, Columbus, IN
What is the white square "vent" between the wheel and access door?2018 TAB400 - M@ry-Christine, White/Black, 2017 Chevy Silverado 2500HD, White
That's the battery box vent.Pat, Steve, Rowdy & Shadow
2018 T@B 400 - "T@KO T@B" -
I plan on taking delivery of my new trailer July 16 and heading straight to UCamp18. I have yet to see my T@B in person, and these are the only photos I have. I am excited I will see it in two and a half weeks! @Verna Thank you for the information on the hitch height, it is extremely helpful!N@VENOTSE
SF Bay Area -
So did you ask on axle height, or trailer body compared to regular trailer 400? Doesn’t have to be much but here in Utah I’ve seen clearance issues... I wouldn’t change much on mine but this is a great start. Next would be tp dispenser built in to sink🤔
Ok at nucamp the sales guy stated that the axle height is somewhere between 2 1/2 to 3 inches higher. They put an off-road tread tire on. They did not change sidewall strength from the old style. Personally the tread doesn’t matter unless u put power to it. When u go off road and u watch side wall flex I would strengthen that. I know how I’ll order mine. Do we need bounce in tire for softer ride while driving so it doesn’t rattle it apart? I’m in my first year of trailer camping. U can also order trim in multiple colors that our dealers should have the color chart for. Not mine. The wheel well and fender changed size a bit to accommodate the on off of a tire.
@Drewcarrie, not sure what you need to know, but the 400 boondock may give you more clearance, it was not designed for rough, off-roading. Did you mean you were not given the opportunity to order a select color? How will you order your 400?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 917 Introductions
- 73 Teardrop Groups & Links
